someone please help!!!
Old Oct 28, 2007 | 11:09 PM
slikahz's Avatar
Default someone please help!!!
hey everyone i have a 96 integra and jus recently my car starts to shake like crazy when i put it into first and wen i start taking off. and when i try to put it into second, third or fourth it grinds. when im in first waiting for the light to turn green the car just stalls on me even tho i didnt even let the clutch go. would someone please help me.
Old Oct 28, 2007 | 11:17 PM
bigkvn77's Avatar
Default Re: someone please help!!! (slikahz)
Sounds like your clutch slave or clutch master cylinder is going bad. Check the fluid level in your clutch master cylinder. Look around the master for any leaking fluid. Check the rubber clutch line for any leaks. Lastly check the slave for leakage. Pull back the boot that covers the piston and inspect it. If nothing is found. Refill bleed and check back on it from time to time. It might be a small leak/seapage.
Its and ez fix...you got this
Old Oct 29, 2007 | 06:30 PM
slikahz's Avatar
Default Re: someone please help!!! (bigkvn77)
thanx for the reply man ill try that on the weekend cause i dont have time because i have work. im driving like that to and from work monday through friday. do u think it would get even worse? and btw that same thing happened to my 93 prelude in march so i have a lil experience with that. the situation was a little different but its worth a try.
Old Oct 29, 2007 | 08:43 PM
95teg_ls's Avatar
well if its grinding its ruining your transmission, i wouldnt recommend driving it like that, try to take a look at it whenever you can.
Old Oct 29, 2007 | 08:54 PM
LordAphotic's Avatar
check your mounts. if your mounts are good then its going to be the clutch...
im leaning more towards the clutch but the mounts are easy to check and could solve your problem.
Old Oct 30, 2007 | 09:18 AM
95 integra's Avatar
Default Re: (LordAphotic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LordAphotic &raquo;</TD></TR><TR><TD CLASS="quote">check your mounts. if your mounts are good then its going to be the clutch...
im leaning more towards the clutch but the mounts are easy to check and could solve your problem.</TD></TR></TABLE>
Old Oct 30, 2007 | 01:17 PM
Rainmaker's Avatar
This is also the type of problem that can strand you, so keep that in mind.
Old Oct 30, 2007 | 09:36 PM
slikahz's Avatar
Default Re: someone please help!!! (Rainmaker)
hey rain maker u were right. i am stranded. AT HOME. haha. i guess i have time to fix it now. jus to update u guys now, my car would start but it wouldnt go into any gear at all. the last time that happened it was my clutch in my prelude.
Old Oct 31, 2007 | 05:51 AM
integtegluver's Avatar
im not to sure but could be ur sinkernisors and sorry if i spelled it wrong but talk to slo_hatch he could tell u more and check ur tanny fluid
Old Oct 31, 2007 | 06:49 AM
dizzzane's Avatar
Default Re: someone please help!!! (integtegluver)
I don't know why you would check you mounts, guess its not hurting anything.
That "shake" is the clutch chattering, you need to replace it and then bleed your lines.
Old Nov 6, 2007 | 07:18 PM
slikahz's Avatar
Default Re: someone please help!!! (dizzzane)
ok heres an update. i found out that it was the clutch and i went to get a stage 2 competition clutch.
Old Nov 6, 2007 | 07:36 PM
CarFreek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigkvn77 &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like your clutch slave or clutch master cylinder is going bad. Check the fluid level in your clutch master cylinder. Look around the master for any leaking fluid. Check the rubber clutch line for any leaks. Lastly check the slave for leakage. Pull back the boot that covers the piston and inspect it. If nothing is found. Refill bleed and check back on it from time to time. It might be a small leak/seapage.
Its and ez fix...you got this </TD></TR></TABLE>
I don't think you need a new clutch.
Sounds like it's just a leek.
If you have a leek, as the presser bleeds off it's the same as
taking your foot off the clutch slowly.
Witch would make your car stall wile sitting at a light.
FRKWOO
Apr 5, 2009 03:58 AM
patrick4588
Aug 31, 2008 05:58 PM
ej1-usdm
Dec 5, 2007 04:03 AM
GraphiteMW
Mar 25, 2007 09:26 AM
JLange
Mar 30, 2003 04:31 PM
