window issue.
Old Dec 3, 2007 | 01:02 PM
dohc_profile's Avatar
Default window issue.
ok searhced but didnt get my answer. my driver side window when fully raised leans forward, as in towards the front of the car. and pops out towards the outside of the car. my car is missing the plug/bolt that goes in the top back corner. if i replace this plug will the window correct itself? or will i need to do any adjustments behind the door panel? does this plug have the same part number as a honda. i dont have an acura dealerhsip in my city, only honda.
Old Dec 3, 2007 | 01:07 PM
IZEONLI's Avatar
Default Re: window issue. (dohc_profile)
that bolt should correct the problem u should have 1 on each side of the window n that what helps keep it on track. as for the p/n honda may have the same bolt but it may be under a diff. p/n what u can do is call any acura dealership even if out the city and get the p/n then take that 2 Honda n they can ref. and c if they have anything that matches. thats what i used to do with my DA when i worked at a honda dealer.
Old Dec 3, 2007 | 02:03 PM
ok thanks man. im pretty sure the other bolt is behind the door and cant be seen?
Old Dec 3, 2007 | 02:17 PM
Default Re: (dohc_profile)
i think i have the right numbers.. parts 20,21,22,23. anyone wanna confirm this
http://www.sonsacuraparts.com/...Irno=
Old Dec 6, 2007 | 07:59 PM
civic_eg's Avatar
I had the same problem when I had the car dude! that plug kept getting loose... just replace and you'll be fine.....
Hondaelementaz
Honda CR-V & Element
May 26, 2018 01:58 AM
9.3.S.I.L.U.D.E.
Dec 3, 2009 08:19 AM
randep
Aug 4, 2008 07:00 AM
bond1973
Jan 20, 2005 06:57 PM
