Axle removal problem
Old Dec 5, 2007 | 09:48 AM
B6tizzleHatch's Avatar
Default Axle removal problem
YES I searched.
98 Gsr, passanger side axle. I cant seem to seperate the shaft from the tranny.
Ive tried about 6 different pry bars. Ive tried the rachet strap idea.
Still no luck.
Any thoughts/suggestions whould be helpfull.
thanks.
Old Dec 5, 2007 | 09:59 AM
95 integra's Avatar
Default Re: Axle removal problem (B6tizzleHatch)
small screw driver and a sledge hammer
Old Dec 5, 2007 | 10:00 AM
all-mtr-teg's Avatar
Try using 2 prybars or 2 large screw drivers at the same time, if you only pry the axle on 1 side at a time, it may kink but using 2 at the same time has always worked for me.
Old Dec 5, 2007 | 10:14 AM
LordAphotic's Avatar
if u have lsd u can remove one axle then poke the other one out through that hole....
putting a prybar or a screw driver on one side usually doesnt help if its jammed cause its machined so perfectly that if u try to angle it like that it just keeps it stuck.... try to use atleast two prybars or screwdrivers from different angles..... use one as a lever with one hand and hammer on the other one with the other hand....
DO NOT LAY UNDER WHERE UR HAMMERING
cause if it happens to fall even a 2lb tool can bust ur face open....
Old Dec 5, 2007 | 01:53 PM
Fern413's Avatar
Default Re: Axle removal problem (all-mtr-teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">Try using 2 prybars or 2 large screw drivers at the same time, if you only pry the axle on 1 side at a time, it may kink but using 2 at the same time has always worked for me.</TD></TR></TABLE>
thats about it...it always works.. g/l tho..
Old Dec 5, 2007 | 04:25 PM
JRSC01GS-R's Avatar
Default Re: Axle removal problem (Fern413)
ive always used my 2 foot pry bar from above and pryd a little on each side a couple of times, then I just give it a quick jerk and it usually just pops out.
if all else fails get two pry pars and a buddy and one person pry from above and one person from below and it will come out for sure
usually its seperating the drivers side axle from the intermediate shaft that sux, but a 1/2 drive 12'' extention and a sledge hammer gets it done everytime
Old Dec 5, 2007 | 05:02 PM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Default Re: (LordAphotic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LordAphotic &raquo;</TD></TR><TR><TD CLASS="quote">if u have lsd u can remove one axle then poke the other one out through that hole....</TD></TR></TABLE>
That's true, never thought about that.
I think I'll buy a itr tranny just for that reason.
Old Dec 6, 2007 | 10:08 AM
Default Re: (CARMA_626)
Ive tried two pry bars at once.
The problem is I dont have much acess to get a large pry bar in there.
Im just going to drop the tranny (motor is coming out for a winter project)
So Ill just fo it that way.
Thanks for the suggestions
Old Dec 6, 2007 | 05:39 PM
_oemek_'s Avatar
not imlying that your stupid. but did you undo the 3 half shaft bolts? they shouldnt be that hard. usually a little struggle but not that bad.
Old Dec 6, 2007 | 06:02 PM
tegman23's Avatar
did you or somone put a obx lsd in there??because i have one and you have to pound on the axle to get it out!!
Old Dec 6, 2007 | 07:18 PM
berb_15's Avatar
Default Re: Axle removal problem (_oemek_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _oemek_ &raquo;</TD></TR><TR><TD CLASS="quote">not imlying that your stupid. but did you undo the 3 half shaft bolts? they shouldnt be that hard. usually a little struggle but not that bad.</TD></TR></TABLE>
arent those are on the drivers side?
I pried and pried and couldnt get mine out then I put my foot on a pry bar and hit the axle with a standard hammer and it popped right out... wish I would have tried that to begin with
Old Dec 6, 2007 | 07:35 PM
DC2Hedi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">DO NOT LAY UNDER WHERE UR HAMMERING
.</TD></TR></TABLE> yeah that **** really hurts ill tell ya what i thought about wearing a football helmet and some saftey glasses the next time i do anything in a tight area like that
Old Dec 6, 2007 | 09:03 PM
_oemek_'s Avatar
Default Re: Axle removal problem (berb_15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by berb_15 &raquo;</TD></TR><TR><TD CLASS="quote">
yes they are i have my sides mixed up. sorry for my neglagence.
I think if you can hit the axle at the CV Join housing with a hammer it might help free up the C clip thats inside. I have trouble sometimes and that usually helps. Sometimes the "C" clip at the end of the axle is doin its job to well.
Old Dec 6, 2007 | 09:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegman23 &raquo;</TD></TR><TR><TD CLASS="quote">did you or somone put a obx lsd in there??because i have one and you have to pound on the axle to get it out!!</TD></TR></TABLE>
I know the car has an aftermarket LSD. Im not sure of the brand (cant remember off the top of my head) But I have the reciept from the previous owner.
I wasnt sure if I had to do that or not, Ive removed several axles before but none which had a hydro tranny. They were all B series EFs.
So the question now is, Does the half shaft need to be removed?
(Im gonna feel like an idiot if it does)
Old Dec 6, 2007 | 09:11 PM
Passenger side doesn't have the intermidiate shaft with the 3 mounting bolts, that's the driver side.
Old Dec 6, 2007 | 10:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">Passenger side doesn't have the intermidiate shaft with the 3 mounting bolts, that's the driver side.</TD></TR></TABLE>
I know that, but I wasnt sure if it had anthing to do with the removal on the passanger side.
I spent anthor two hours messin with it tonight. still nothing....
My only option now is to pull the transmission with it in there and then seperate the two.
Old Dec 10, 2007 | 11:17 PM
Default Re: (tegman23)
YES. previous owner (cloose friend) had one installed.
He mentioned when it was first installed it kept making a popping noise that he couldnt figure out.
How the hell did you get your out?
Old Dec 12, 2007 | 10:30 AM
Default Re: (B6tizzleHatch)
BUMP
Any answers to removing my axle from the tranny/lsd (obx lsd)
Anyone had or known of similar problems?
Old Dec 12, 2007 | 11:33 AM
JRSC01GS-R's Avatar
if passenger side is too stubborn u can always try to take out the intermediate shaft and then try hittin passenger side out throught the hole in diff
Old Dec 12, 2007 | 10:19 PM
Default Re: (JRSC01GS-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRSC01GS-R &raquo;</TD></TR><TR><TD CLASS="quote">if passenger side is too stubborn u can always try to take out the intermediate shaft and then try hittin passenger side out throught the hole in diff </TD></TR></TABLE>
Already tried that when the motor was still in.
Havent tried it since I pulled everything
BUMP?
Old Dec 13, 2007 | 03:33 AM
92integraVTECgsr's Avatar
just get a good strong and long pry bar and make sure you got it in a good position so that it wont slip and pry the **** outta it.. you might need to just use the hammer and bar or screw driver and bang the axle out of there. That is what I had to do the other night trying to get my driver's side axle. It had never been changed before (2000 gsr) and i couldnt pop it out so i hammer it out.
Old Dec 13, 2007 | 10:20 AM
Default Re: (92integraVTECgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr &raquo;</TD></TR><TR><TD CLASS="quote">just get a good strong and long pry bar and make sure you got it in a good position so that it wont slip and pry the **** outta it.. you might need to just use the hammer and bar or screw driver and bang the axle out of there. That is what I had to do the other night trying to get my driver's side axle. It had never been changed before (2000 gsr) and i couldnt pop it out so i hammer it out. </TD></TR></TABLE>
No room to physically hit the axle. Ive tried 4 pry bars.
I even modified a few pry bars and nothing, Hell I broke 2 pry bars
If the weather warms up a little in the next few days im gonna go out in my garage and seperate the tranny and motor and then expletive with it again.
Ill give you guys an update whenever i do that
Old Dec 13, 2007 | 02:03 PM
RamenDA9noodles's Avatar
ive always used a ball-joint separator. works every time for me.
Old Dec 13, 2007 | 05:20 PM
JRSC01GS-R's Avatar
Default Re: (RamenDA9noodles)
yea ive done that too, it works pretty well
Old Dec 13, 2007 | 05:32 PM
Dogginator's Avatar
Daisy... Daisy...
The early OBX LSDs are notorious for sticking axles.
https://honda-tech.com/zerothread?id=1249085
