Shifter Problem
Old Dec 3, 2007 | 03:34 PM
Extreez's Avatar
Default Shifter Problem
I have spotted a recent problem and finnally got annoyed wit a old problem, I have a B&M Short Shifter installed with a Type R Replica shift ****, everytime i let go of the gas i hear a LOUD ratteling noise, not only that i see alot of motion with the accelerating and deaccelerating, by this i mean for example lets say Im in 3rd gear i see the shifter moving back and fourth.
Old Dec 3, 2007 | 07:58 PM
jhammond_82's Avatar
Reject Papi
Default Re: Shifter Problem (Extreez)
i think every car i've owned has done that. but.....check your shifter bushings, and hardware to make sure that it is tight. maybe the little bushing on the pivot of the shifter, is shot.
Old Dec 3, 2007 | 11:11 PM
Extreez's Avatar
Default Re: Shifter Problem (jhammond_82)
just changed the shifter bushing to polyurathane, thinking that it would stop the rattle, but question is what bushing should i look for that actually goes on the linkage that connects to the short shifter, the ones i got was the other linkage which doesnt connect to the short shifter linkage.
Old Dec 4, 2007 | 04:45 AM
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Extreez &raquo;</TD></TR><TR><TD CLASS="quote">by this i mean for example lets say Im in 3rd gear i see the shifter moving back and fourth.</TD></TR></TABLE>
Front to back:
This is normally the cause of shot motor mounts.
Old Dec 4, 2007 | 05:43 AM
Reject Papi
Old Dec 4, 2007 | 03:18 PM
Extreez's Avatar
Default Re: Shifter Problem (AWD Terror)
i just replaced all 4 mounts, should i maybe get inserts ?
Old Dec 4, 2007 | 03:42 PM
berb_15's Avatar
I dont think it's anything to be too worried about unless it's excessive, and it's hard to tell what excessive is... but as awd terror said it's usually just your motor shifting around in the engine bay. My brothers truck and my jeep both have long sticks and you can really see those things move around when theres a change in acceleration
Old Dec 4, 2007 | 04:43 PM
Extreez's Avatar
Default Re: Shifter Problem (berb_15)
nothing that im too worried about, its the rattle that is getting me now, it just gets annoying and i wanted to see what you guys have done to change that
Old Dec 11, 2007 | 06:02 AM
berb_15's Avatar
Is the shifter hitting your exhaust by any chance?? I had that problem I had to lower my exhaust slightly... where is the rattle coming from??
Old Dec 11, 2007 | 06:09 AM
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by berb_15 &raquo;</TD></TR><TR><TD CLASS="quote">Is the shifter hitting your exhaust by any chance?? I had that problem I had to lower my exhaust slightly... where is the rattle coming from??</TD></TR></TABLE>
Make sure of the shifter + exhaust problem.
Old Dec 11, 2007 | 07:02 PM
Extreez's Avatar
really doubt its hitting the exhaust, theres about a finger and half gap between the exhaust and shifter, sounds like its the little ball that connects to the shift linkage is rattling.
Old Dec 11, 2007 | 10:55 PM
TURBODC4TEG's Avatar
when u hit the gas does the shifter rattle? if so the exhaust vibrates and moves alittle probably tapping the shifter some. mine does it
Old Dec 12, 2007 | 01:41 PM
Extreez's Avatar
Default Re: Shifter Problem (TURBODC4TEG)
when i let go of the gas it rattles
Old Dec 13, 2007 | 04:56 PM
ebola_one's Avatar
On my DA I've noticed that the shift linkage is pretty loose up by point 22 (the U joint)
I'm contemplating drilling the horizontal pin out & putting a bolt through with a few washers to keep it moiving.
I'd also look at giving point 28 a bit of a nip up.
can you get a buddy to sit in the drivers seat & give the throttle a bit of a stab while you're under the car to see what's actually moving down there?
Old Dec 13, 2007 | 05:25 PM
Extreez's Avatar
Default Re: Shifter Problem (ebola_one)
the u joint is sorta loose when i was underneath while back so thats one, maybe replacing the shift linkage would fix ?
Old Dec 13, 2007 | 07:09 PM
A's 94 GSR's Avatar
BG-33P
Only when I let off the gas is when the shifter vibrates like crazy. It's pretty annoying too.
Old Dec 13, 2007 | 08:09 PM
Extreez's Avatar
Default Re: Shifter Problem (A's 94 GSR)
same here
gameknb
Jun 11, 2005 07:32 AM
blackjdmEKcivic
Feb 25, 2005 01:52 PM
starbury
Feb 15, 2005 09:58 AM
STHPERFORMANCE
Jul 6, 2003 07:28 PM
Regular Series
Sep 14, 2002 10:41 AM
