rattle???
Old Dec 3, 2007 | 04:22 PM
miketrue's Avatar
Default rattle???
When i rev my 99 integra to 1.5k theres a high rattle sound. Sounds like the cat but im not sure. Its coming from underneath the car. what do you guys think? Also if it is the cat, what would be causing the rattling, and would this prevent me from passing smog?? Thanks alot.
Old Dec 3, 2007 | 06:00 PM
1Point8DC2's Avatar
Default Re: rattle??? (miketrue)
Check your heat shields.
Old Dec 3, 2007 | 08:32 PM
SaYwOrd54's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1Point8DC2 &raquo;</TD></TR><TR><TD CLASS="quote">Check your heat shields. </TD></TR></TABLE> yep i had the same problem, removed my cat heat shield and problem fixed.
Old Dec 3, 2007 | 08:38 PM
VTEC_PRODUCTION's Avatar
Default Re: rattle??? (SaYwOrd54)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SaYwOrd54 &raquo;</TD></TR><TR><TD CLASS="quote"> yep i had the same problem, removed my cat heat shield and problem fixed. </TD></TR></TABLE>
its not really a good idea to remove the heat shield. its really malleable anyway you should just be able to bend it. just put the car on stands or ramps and check it underneath there...
Old Dec 3, 2007 | 09:06 PM
TurboTigerTeg's Avatar
another option is to use pipe clamps on the heat shield to keep it from vibrating. I would have to agree that its not a great idea to remove the heat shield.
Old Dec 3, 2007 | 09:21 PM
St Jimmy's Avatar
* B A N N E D *
Default Re: rattle??? (VTEC_PRODUCTION)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_PRODUCTION &raquo;</TD></TR><TR><TD CLASS="quote">
its not really a good idea to remove the heat shield. its really malleable anyway you should just be able to bend it. just put the car on stands or ramps and check it underneath there...</TD></TR></TABLE>
Thats your best bet.
And no a rattle wont make you fail smog.
Old Dec 3, 2007 | 09:25 PM
SWE3TDUDE's Avatar
Default Re: rattle??? (St Jimmy)
I also have this same mysterious rattle but mine happens at 2.2k RPM. I have checked underneath the car but everything seems to be in place, hard to pin point the noise when you cannot simulate it while its raised up. So is the problem confirmed to be the cat shield? I don't know if removing that would be a great idea, its there to deflect the heat away and with that gone, the heat could cause some damage over time.
Old Dec 3, 2007 | 09:27 PM
SWE3TDUDE's Avatar
Default Re: rattle??? (SWE3TDUDE)
Any idea why it only happens at a certain RPM? If I go beyond 2.2k RPM, it goes away but if I straggle at 2.2k RPM by releasing the gas, it rattles and sounds like my car is about to fall apart. Its not a big issue but damn its so annoying!
Old Dec 3, 2007 | 10:28 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SWE3TDUDE &raquo;</TD></TR><TR><TD CLASS="quote">Any idea why it only happens at a certain RPM? If I go beyond 2.2k RPM, it goes away but if I straggle at 2.2k RPM by releasing the gas, it rattles and sounds like my car is about to fall apart. Its not a big issue but damn its so annoying!</TD></TR></TABLE>
you can put the car on jacks or stands and look what are you talking about? unless it rattles under load...
Old Dec 3, 2007 | 11:13 PM
miketrue's Avatar
Thanks for all the input. Im going to check it out tomorrow. also how would you go about getting off trial user?? thanks.
-Mike
Old Dec 4, 2007 | 12:03 AM
Doodlydo's Avatar
I have kind of the same problem, but it happens after about 2.5k and gets louder. Think it's a rod bearing... Hoping the exhaust is the problem though lol!
Old Dec 4, 2007 | 12:58 AM
SWE3TDUDE's Avatar
Default Re: rattle??? (Doodlydo)
Mine doesn't get progressively louder, it just happens at that specific RPM...you scared me by mentioning rod bearing...I hope its just a loose heat shield or something.
Old Dec 4, 2007 | 01:29 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SWE3TDUDE &raquo;</TD></TR><TR><TD CLASS="quote">Mine doesn't get progressively louder, it just happens at that specific RPM...you scared me by mentioning rod bearing...I hope its just a loose heat shield or something.</TD></TR></TABLE>
quit pissin, look, and then get back to me
Old Dec 4, 2007 | 07:43 AM
SWE3TDUDE's Avatar
Hey guy, I stated below that I did look and everything seemed normal but the rattle still exists at 2.2k RPM. Get back to me when you have something constructive and helpful to contribute.
Old Dec 4, 2007 | 12:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SWE3TDUDE &raquo;</TD></TR><TR><TD CLASS="quote">Hey guy, I stated below that I did look and everything seemed normal but the rattle still exists at 2.2k RPM. Get back to me when you have something constructive and helpful to contribute. </TD></TR></TABLE>
take a harder look
Old Dec 4, 2007 | 08:52 PM
vwong's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miketrue &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for all the input. Im going to check it out tomorrow. </TD></TR></TABLE>
Have you checked it out yet, Mike? BTW, which side of the tail light do you need? I found a driver side tail.
Old Dec 5, 2007 | 04:10 AM
Integra0057's Avatar
same thing just happend to me within the past couple of days and it was the heat shield on the cat just welded it and used pipe clamps to clamp it together no rattle anymore.
Old Dec 5, 2007 | 07:13 AM
Byaaah!'s Avatar
Jet Life Til' The Next Life
Default Re: (Integra0057)
Yank that bish off...
p-p-porkchop
Oct 14, 2008 12:59 PM
tgreene2098
Jul 20, 2007 08:22 PM
escape2me
Oct 29, 2005 10:42 PM
starbury
Feb 15, 2005 05:09 PM
Poey2
Aug 15, 2003 08:05 AM
