Ignition Switch
Old Dec 1, 2007 | 06:06 PM
da_33's Avatar
Default Ignition Switch
If my ignition switch had gone bad, would I still beable to bump start the car? Or does that not matter?
Old Dec 1, 2007 | 06:59 PM
blkb18's Avatar
Default Re: Ignition Switch (da_33)
It would depend on what part of the switch is bad. If you can physicaly turn it to the accessory position and everything seems normal then it may bump start.
Old Dec 1, 2007 | 07:23 PM
1Point8DC2's Avatar
Default Re: Ignition Switch (blkb18)
as long as the electrical contacts are closing then it should work.
Old Dec 1, 2007 | 07:57 PM
da_33's Avatar
bc it will start everyone if i bump start it when it wont turn over. I have another post about this but money is tight right now and its narrowed down to ignition switch or starter. Bc it just kinda turns over when it wants too
Old Dec 27, 2007 | 12:54 PM
da_33's Avatar
Update: So I was having those problems starting but it would always bump start, I had a key that I had cut awhile back bc the one I was using is really worn out and it seemed to work great started everytime for awhile.
Well now im back to the way it used to be before its giving me a hard time. So I wanna replace the ignition. What exactly do you have to replace and will I need a new key? Also anyone have any ideas where I can get what I need??
07JKX
Aug 26, 2015 04:31 PM
slq576
Nov 19, 2013 07:50 PM
allgo88
Apr 5, 2010 08:50 AM
carve
Sep 12, 2009 09:35 PM
infamouskillas
Feb 24, 2008 07:34 PM
