--Power Window Problem--
Old Dec 2, 2007 | 11:58 PM
ColMustard's Avatar
Default --Power Window Problem--
This is on a 94 Integra 2dr
I recently changed my combination switch because my wipers werent working. Before i began i rolled the driver side window down, i changed it out and bam my wipers work again. I shut the car off and start it later to roll up my window and it doesnt roll up.
1. BOTH windows dont roll up or down using BOTH switches
2. Moonroof doesnt work now
3. Wipers dont work now
Checked the fuses under the dash, and all seem ok.
I am stummped, and its ****** cold outside, please help
Is there a relay i am missing or could i have shorted something out
Old Dec 3, 2007 | 12:17 AM
1sloej6's Avatar
Default Re: --Power Window Problem-- (ColMustard)
double check all the fuses....one at a time if you have to also check the under hood fuses...if all is ok then take off your combination switch, and try with old one
Old Dec 3, 2007 | 12:54 AM
ek4shizzle's Avatar
Default Re: --Power Window Problem-- (1sloej6)
number 36 fuse(50A) underhood fuse box.
Old Dec 3, 2007 | 01:12 AM
slammedz6ef's Avatar
my cousin had the same problem with the driver and passenger side window, it was a bad ground connection.........
but with your problem with your wiper and sunroof, i would check the fuse or the connections
Old Dec 3, 2007 | 10:13 AM
ColMustard's Avatar
Default Re: --Power Window Problem-- (slammedz6ef)
I figured out that it was No.14 20a fuse under the dash. Didnt know there was a relay fuse. It is a PW rly, MR Rly, and Combo Switch. I missed it somehow, everything works good now, thanks for the help
smoked08
Sep 13, 2010 07:04 PM
db94
Feb 13, 2008 01:19 AM
RP215.
Jan 29, 2007 06:12 PM
91integraLSVTEC
May 10, 2005 01:15 PM
jsmooney
Jun 1, 2004 07:05 PM
