vtec
Old Dec 4, 2007 | 07:13 PM
BEATINTEGRA's Avatar
Default vtec
ok my vtec swap is acting up it seems to only work when it wants to. it kicks in at 4500 rpm which i've been told is too early but i have an ls tranny so i guess im better off. i dont have a knock sensor hooked up and i have read that vtec wont work with out this. mine works just once in a while. two vtec wires are hooked up could it be the coolant temp sensor?
Old Dec 4, 2007 | 08:05 PM
GSR in progress 96's Avatar
* B A N N E D *
Oil?
Old Dec 5, 2007 | 11:08 AM
dickdragon's Avatar
vtec sel.
vtec pess. switch
& you should need a ks
Old Dec 5, 2007 | 02:06 PM
weavertime1's Avatar
Default Re: vtec (BEATINTEGRA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BEATINTEGRA &raquo;</TD></TR><TR><TD CLASS="quote"> could it be the coolant temp sensor?</TD></TR></TABLE>
A do not believe a coolant temp sensor can make the vtec not engage properly. You do need a knock sensor tho. Good luck!
Old Dec 5, 2007 | 03:05 PM
Dogginator's Avatar
Daisy... Daisy...
What engine and ECU are you running? Include the year. Any CELs?
gshatch
Jun 21, 2008 11:35 AM
h22ek9forme
Nov 12, 2007 10:48 AM
mikebranson
Apr 13, 2004 09:00 PM
rainmanef
33
Feb 4, 2004 06:47 PM
22civic
Jun 21, 2002 04:45 PM
