cigarette lighter doesn't work
Old Dec 5, 2007 | 11:29 AM
goheel's Avatar
Default cigarette lighter doesn't work
My CD Player works though. I don't know if it could be the fuse. I don't smoke, but I would like to use the lighter to plug in my GPS system.
Old Dec 5, 2007 | 11:41 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: cigarette lighter doesn't work (goheel)
if you don't know if it's the fuse, start there
Old Dec 5, 2007 | 11:42 AM
AWD Terror's Avatar
Default Re: cigarette lighter doesn't work (GRAF-FITI)
The lighter assembly is very easy to take out. Pull it, and see if it works.
Old Dec 5, 2007 | 12:30 PM
goheel's Avatar
Default Re: cigarette lighter doesn't work (AWD Terror)
how do i test to see if it works or not?
Old Dec 5, 2007 | 12:43 PM
Boostin_GSR's Avatar
Take a test light and hook it to a good ground. Then, you take the pointy part and stick it down into the lighter onto the metal. If the light lights then that means it's getting power if not then no power. Then you would test your fuses with the test light.
Old Dec 5, 2007 | 02:59 PM
Infamous_Imports's Avatar
Default Re: cigarette lighter doesn't work (Boostin_GSR)
I'm having the same problem-But I have one other problem; the fuse diagram that goes in the bottom of the dash underneath the coin holder...yea umm I lost it; so does anybody have a layout of the fuse diagram so I can check which fuse goes to the cigarette lighter. I would like to use my car charger sometime in the near future lol.
TIA
Old Dec 6, 2007 | 09:53 AM
Default Re: cigarette lighter doesn't work (Infamous_Imports)
Test em all with a test light until you find one that's blown.
Old Dec 7, 2007 | 07:20 AM
Have you ever seen how many fuses are down there. Sorry if I don't have as much time as you to test them all. So if somebody could provide the guid or a link to the guide i'm sure me and the poster would appreciate it.
Old Dec 7, 2007 | 07:59 AM
GSR-TRBO-DA's Avatar
Default Re: (Infamous_Imports)
there is only like 20 you must not want this to be fixed then.
Old Dec 7, 2007 | 08:36 AM
AWD Terror's Avatar
Default Re: (GSR-TRBO-DA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR-TRBO-DA &raquo;</TD></TR><TR><TD CLASS="quote">there is only like 20 you must not want this to be fixed then.</TD></TR></TABLE>
Way to be productive. Find a picture or STFU
Old Dec 7, 2007 | 08:37 AM
jhammond_82's Avatar
Reject Papi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Infamous_Imports &raquo;</TD></TR><TR><TD CLASS="quote">Have you ever seen how many fuses are down there. Sorry if I don't have as much time as you to test them all. So if somebody could provide the guid or a link to the guide i'm sure me and the poster would appreciate it. </TD></TR></TABLE> as long as it took you to type that, you could have pulled half of the fuses!
Old Dec 7, 2007 | 08:42 AM
AWD Terror's Avatar
Look in the helms, or go here http://www.hondahookup.com/manuals/
Old Dec 7, 2007 | 01:56 PM
Default Re: (jhammond_82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhammond_82 &raquo;</TD></TR><TR><TD CLASS="quote"> as long as it took you to type that, you could have pulled half of the fuses!</TD></TR></TABLE>
And as long as it took you to type that you could have found a picture...thanks have a great day.
Thanks AWDTerror
elmejor
Nov 6, 2008 11:57 AM
darksolderx
Jun 25, 2008 01:43 PM
kercha83
May 25, 2008 11:46 AM
SpeedoKing
Jul 18, 2007 06:57 PM
OEM-
Feb 28, 2007 11:36 AM
