check engine light is resetting by itself
Old Dec 3, 2007 | 04:19 PM
HmgLauj69's Avatar
Default check engine light is resetting by itself
cel goes away when i turn off the car. how do i pull the code when the cel wont come back on? i've yet to try it with the car running, does this work?
Old Dec 3, 2007 | 04:28 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: check engine light is resetting by itself (HmgLauj69)
The first thread in the Integra FAQ will help:
https://honda-tech.com/zerothread/1230496
Old Dec 3, 2007 | 06:56 PM
HmgLauj69's Avatar
Default Re: check engine light is resetting by itself (Dogginator)
how does that help?
Old Dec 5, 2007 | 03:26 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HmgLauj69 &raquo;</TD></TR><TR><TD CLASS="quote">how does that help?</TD></TR></TABLE>
I reset this thread a bit. Your question is apparently not clear.
What do you mean by the CEL goes away when you turn off the car? The computer will store the fault code, but will not reilluminate the CEL until the fault occurs again. Have you tried to pull the CEL with the link provided above? If so, what was the result?
Old Dec 5, 2007 | 09:15 AM
HmgLauj69's Avatar
*sigh*
topic title "check engine light is resetting by itself "
when driving sometimes the CEL comes up. when i turn off the car (in order to pull to code) the CEL wont blink. if i unplug the jumper and start the car or set to the "ON" position the CEL is gone. hence resetting by itself.
i dont know how i can be more clear
Old Dec 5, 2007 | 09:35 AM
Amped's Avatar
Does the car run ok? Then keep driving it till the computer sees a problem. if you cant get codes then there nothing to worry about.
Old Dec 5, 2007 | 09:42 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HmgLauj69 &raquo;</TD></TR><TR><TD CLASS="quote">*sigh*
If many people misinterpret what you wrote the exact same way, the fault lies in how you wrote it. The word "resetting" could mean that the light simply turns off or you cannot pull the codes.
Go to your local auto parts and have them try to pull the codes with the code reader. They should do this for free. If they cannot pull the codes, you could have a memory power issue with your ECU or simply a bad ECU.
Old Dec 5, 2007 | 09:50 AM
integra686's Avatar
What year is the car? if it's obd-1 then yes it will turn off, but you will still be able to get the code. My gs-r has the same problem but i still can get my o2 sensor code. if it's obd-2 then you should still have a pending code in the ecu.
Extreez
Sep 22, 2007 05:43 PM
stealth89hatch
Aug 15, 2005 04:48 PM
game over
Feb 19, 2005 06:15 PM
BlkGSR
Jun 18, 2003 07:11 PM
