transmission problem.....help.!!
Old Dec 1, 2007 | 02:27 AM
knight_kidD's Avatar
Default transmission problem.....help.!!
most of the time when i drive and put it in neutral it wouldn't allow me to put it in any gears. but when i do a complete stop i'm able to put it in gear. anybody happen to know what can cause this..? what might the problem be...
Old Dec 1, 2007 | 06:46 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: transmission problem.....help.!! (knight_kidD)
I'll make the bold assumption that you are asking about a manual transmission.
What if you are stopped with the car in neutral and the clutch out and the depress the clutch and try to select a gear? (engine running of course)
Have you checked your transmission fluid level?
Old Dec 1, 2007 | 11:52 AM
yes, it's a maunel transmission and yes i've checked the fluid level. the problem is when i drive im able to shift into every gear but when i coast and leave it in neutral im unable to put it back into gear.
unless im at a complete stop.....
Modified by knight_kidD at 11:07 PM 12/2/2007
Old Dec 2, 2007 | 10:13 PM
anybody..?
b
Old Dec 2, 2007 | 11:23 PM
wunfstgsr's Avatar
Loved
Community Favorite
That used to happen to me before my act stage 2 clutch gave out on me, try reving when its in nuetral and then puting it in gear so if it doesnt go in gear hit the gas an put it in gear that always worked for me! hope this helps
Old Dec 9, 2007 | 08:01 PM
Default Re: transmission problem.....help.!! (wunfstgsr)
it doesnt work do u think it can be my whole tranny? well here is some other problems that occurs when im driving.
so i thought it was my clutch. so i change it out and still get stuck in gears. the problem is that when im driving and put it back in neutral im not able to put it back in gear..
also when im on a hill in first and foot on the clutch pedal all the way my car doesnt even roll back.
sometimes when im in neutral and remove my foot off the clutch pedal while at a stop my car stalls out or shut off
what do u guys think the problem is....any suggestion on how to fix it would help thanks....!
Old Dec 11, 2007 | 09:54 PM
anybody??
Old Dec 11, 2007 | 10:08 PM
kraig8's Avatar
the spring on your pressure plate on your clutch assembly might be going out and not disengaging the clutch
Old Dec 11, 2007 | 10:56 PM
steveteggy92's Avatar
Does the handle feel strange in any way, Loose maybe? Could be an issue of it not coming all the way out of gear or something? Shifter linkage problem maybe? You looked at that stuff yet?
Old Dec 12, 2007 | 03:30 AM
Dogginator's Avatar
Daisy... Daisy...
What car is this? Is it a cable transmission? Did you adjust the cable?
Old Dec 13, 2007 | 05:30 AM
lmike6453's Avatar
if it's a hydro it could be the master and/or slave cylinder...mine is leaking on me now...check behind your clutch pedal to see if there is any fluid or gunk
Old Dec 13, 2007 | 05:33 AM
AWD Terror's Avatar
Default Re: (lmike6453)
Could be the pressure plate. You did change that with the clutch, right?
Eddie99
Honda S2000
24
Oct 16, 2007 01:22 PM
chocolatesk8er10
Jul 25, 2007 11:24 AM
integracura
Apr 18, 2007 11:18 AM
Austin
Dec 1, 2003 12:04 PM
ITR111
Mar 15, 2002 06:09 AM
