header question
Old Dec 3, 2007 | 09:58 PM
supracrx's Avatar
Default header question
i know the difference in lengths btwn 00-01 GSR...but are all B series header the same length? 94-99 ls/gsr/rs?
looking at a DC ceramic header used. came off a 00 civic with a b16....would that fit onto my 99 LS? if it doesn't, is all i need to do is cut and weld it shorter or longer?
would it be better to just get a JDM ITR header? just looking for minor mods even tho i know it might not add that much power or anything.
Old Dec 3, 2007 | 10:33 PM
VTEC_PRODUCTION's Avatar
Default Re: header question (supracrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supracrx &raquo;</TD></TR><TR><TD CLASS="quote">i know the difference in lengths btwn 00-01 GSR...but are all B series header the same length? 94-99 ls/gsr/rs?
would it be better to just get a JDM ITR header? just looking for minor mods even tho i know it might not add that much power or anything.</TD></TR></TABLE>
the height is the same. as far as it bolting up im sure it does. as for how far under it goes that length may change.
and if your going to spend money then spend money with a purpose. im not saying ball out but buy a header that gives you bang for the buck. jdm itr ones off ebay arent that great...they do the job but compared to like the dc ceramic header it doesnt compare lol...
Old Dec 4, 2007 | 07:58 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supracrx &raquo;</TD></TR><TR><TD CLASS="quote">i know the difference in lengths btwn 00-01 GSR...but are all B series header the same length? 94-99 ls/gsr/rs?</TD></TR></TABLE>
You have this confused. It is the '94-'99 GS-R that is a different length. All the rest are completely interchangeable.
The B16 header might clear the oil pan, but the flange at the cat is angled differently than on the LS. You'd be better off with the JDM ITR header if that's your other option, though you'll still need a custom high-flow cat.
Old Dec 4, 2007 | 08:45 AM
supracrx's Avatar
hmm ok well i might know someone that can get me a good deal for a JDM ITR header. not the ebay ones but the real ITR ones.
im looking at the DC ones since they're cheap if i can find one used. but i just dont know the difference. if its just length on the bottom i'm sure i can get the muffler shop to cut and reweld it...but i wanted to make sure. but if the flange is different i rather not have them angle the flande differently.
i'm trying to piece together the exhaust system and the header is the last thing i'm trying to find. i can't find a used LS one. other then the length, are all B series CAT the same flange and angled the same way?
Old Dec 4, 2007 | 09:06 AM
k624ash's Avatar
Default Re: (supracrx)
i held a b16 header up to an ls block once and it wouldnt work, the header hit the oil pan. This might vary according to brand, but the one i had didnt work, i think it was a DC
the itr one should work though, i think it will bolt right up
Modified by k624ash at 10:20 AM 12/4/2007
Old Dec 4, 2007 | 04:26 PM
supracrx's Avatar
yea im not sure. want to pick up ASAP but does anyone know which one will not hit the oil pan.. as long as it is just lengths that i can cut to make shorter or longer...
Old Dec 4, 2007 | 04:30 PM
k624ash's Avatar
you can use any b-series except the one for the b16. you might as well stay away from the longer gsr ones though, and get one that bolts right up
Old Dec 4, 2007 | 05:25 PM
supracrx's Avatar
cool....since we're on the subject of this
would the midpipe section of a GSR fit for a LS? or is it longer too? someone told me the bends are the same but just length might be a little different.
Old Dec 4, 2007 | 10:36 PM
supracrx's Avatar
can anyone else confirm that the b16 DC header wont work....lot of ppl are posting that b16 and LS all fit...
Old Dec 5, 2007 | 06:10 AM
k624ash's Avatar
i searched for ya
https://honda-tech.com/zerothread?id=1930628
Old Dec 5, 2007 | 06:16 AM
k624ash's Avatar
Default Re: (k624ash)
https://honda-tech.com/zerothread?id=1279398
note on this one that the guy who said it will fit was swapping in the b16, so he meant it would fit at the flange not at the oil pan since he never tried putting a b16 header on an ls block
Old Dec 5, 2007 | 06:17 AM
k624ash's Avatar
https://honda-tech.com/zerothread?id=1261127
Old Dec 5, 2007 | 06:18 AM
k624ash's Avatar
try a search next time
Old Dec 5, 2007 | 10:57 AM
dickdragon's Avatar
the ports from the head won't line up perfectly. maybe a loss in power.
Old Dec 5, 2007 | 11:28 AM
Padawan's Avatar
Darth ModerVader
Default Re: (dickdragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dickdragon &raquo;</TD></TR><TR><TD CLASS="quote">the ports from the head won't line up perfectly. maybe a loss in power.</TD></TR></TABLE>
That's incorrect. The ports are identical.
Old Dec 6, 2007 | 08:16 PM
supracrx's Avatar
sorry but i understand now..i'll be looking for one that fits.
for the midpipe...the GSR for 94-99 will be about 4.5 inches too long right? i got a cheap midpipe for a 94-99 GSR from a friend. so i'm gonna use that, with a vibrant muffler and have a shop weld it. they should be able to cut it shorter, and weld it?
Old Dec 6, 2007 | 08:18 PM
Padawan's Avatar
Darth ModerVader
Yes, that should be no problem.
Old Dec 6, 2007 | 08:38 PM
supracrx's Avatar
thanks, i'm thinking of the apexi ws2 muffler, or vibrant...want stock looking so i'm not sure yet...
Old Dec 7, 2007 | 10:54 AM
supracrx's Avatar
ok the ws2 has abot 4 inch tip, and vibrant is 3...love the vibrant look but i heard that the vibrant can be loud....my friend has the ws2 and i love how it sounds....
are there any other brand of muffler out there that u guys can recommend?
i want something like a 3inch tip, that sounds like the apexi ws2. is there a way of chopping the tip off and weling a shorter one on...haha
Old Dec 9, 2007 | 12:51 PM
supracrx's Avatar
help me choose guys
Myh4tch
Sep 6, 2010 01:03 PM
nickhans
Jun 9, 2008 09:23 PM
zerogravitycrx
Dec 5, 2006 05:14 AM
mkiv98
Jan 6, 2005 06:42 PM
converge
Nov 30, 2001 11:20 AM
