Halfshaft
Old Dec 8, 2015 | 04:03 PM
Russian21's Avatar
Default Halfshaft
Are all b series half shaft for manual the same. Because I have a da9 with b18a1 motor but the half shaft doesn't fully go in by like 5mm but the bolts align fine. I know that the auto Halfshaft is shorter but if I where to buy a new manual Halfshaft would any fit even from the DC models?
Old Dec 8, 2015 | 05:07 PM
B_Swapped93's Avatar
Default Re: Halfshaft
Yes, if the 3 14mm bolts line up and bolt in with ease you're good to go.
Old Dec 11, 2015 | 02:32 PM
Garage_Spec's Avatar
The DA models came with a male/female halfshaft and the DC models came with a male/male halfshaft. Check what axles you're using and use the appropriate halfshaft to match.
Old Dec 13, 2015 | 01:13 AM
rollinmyda's Avatar
This. Also the seal in the transmission for the halfshaft needs to match the type of halfshaft being used. So for a DA halfshaft use the 90-93 drivers side transmission seal. If you're using a DC halfshaft use the 94-01 seal.
Werf
Jan 4, 2012 10:00 AM
thegatekeeper14
Mar 17, 2008 11:12 AM
JUN.
Feb 5, 2008 02:41 PM
Green Lude 93
Feb 8, 2006 11:26 PM
