help me!!!!
Old Nov 9, 2015 | 03:57 PM
turbo_spitter's Avatar
Default help me!!!!
i have a 92 acura integra with a b18b i just replaced the dizzy, main relay, fuel pump, and o2 sensor. i had the car running befor i did the dizzy and fuel pump and it ran great and then i shut it of cause it was acting weird and it has not wanted to start ever scenes. it will start up and rough idle for a few seconds then die and if i give it pedal it dies right away. i know its getting fuel and spark. so what else could it be i really need help its my daily.
Old Nov 9, 2015 | 04:13 PM
B_Swapped93's Avatar
Default Re: help me!!!!
Correct firing order? it won't be the o2, the main relay wouldn't even let it start so that's most likely fine. the tank has to be dropped for the pump on a DA right...everything hooked up right?. I blame the "new" distributor what is "new" did you get a $700 unit from Honda or a off the shelf part store one, why was it replaced.
Old Nov 9, 2015 | 04:20 PM
yes everything is right and it was one of the pricy ones and i replaced it cause my buddy said it could be the cam sensor in it was messed
Old Nov 9, 2015 | 04:35 PM
So it was from a part store... put the old one back and see what happens. Hondas have a hard time with non OEM ignition components
Old Nov 9, 2015 | 04:37 PM
it dose the same thing with the new one as it dose with the old one it will turn over rough idle for a little then die
Old Nov 10, 2015 | 06:20 PM
stocker2shocker91's Avatar
I requested a short story for a title.
when you replaced the pump did you replace the filter? just because its getting fuel does not mean its getting enough fuel. If you dropped the tank and stirred up a bunch of sediment it could have clogged the filter right up
Merrill Balan
Feb 25, 2023 05:24 PM
Bolo_PR
Jul 26, 2012 07:47 PM
Da9Gro
May 14, 2007 02:29 PM
Mr_Moos
May 5, 2007 10:58 PM
hondastrtracr
May 1, 2006 09:12 PM
