Coolant spill left side of engine
Old Jan 1, 2016 | 11:05 AM
hugodc2's Avatar
Default Coolant spill left side of engine
I'm having trouble pinpointing a small coolant puddle that I see usually after I leave the car over night. Started noticing I'm leaking coolant from somewhere around the left side of the engine. I don't see any top side leaks but usually its right under where my ac compressor used to be
Just wondering if anyone's had this problem before or knows something I don't. Thanks guys.
Car is a 98 Gsr btw
Old Jan 1, 2016 | 09:01 PM
Natsu09's Avatar
Default Re: Coolant spill left side of engine
Car is a 98 Gsr btw
Have you checked around the water pump?
Old Jan 4, 2016 | 02:16 AM
wunfstgsr's Avatar
Loved
Community Favorite
Are you sure its coolant and not oil,
if its coolant prolly from water pump or the radiator.
Old Jan 4, 2016 | 04:48 PM
TheRealTegger's Avatar
Sure looks like oil to me.
If it's coolant and it's that color, then the OP has some pretty big problems.
Old Jan 4, 2016 | 07:18 PM
wunfstgsr's Avatar
Loved
Community Favorite
could also be a power steering leak from the pump or the hose.
Old Jan 10, 2016 | 05:45 AM
K20.ek's Avatar
Looks like oil to me. Just as wunfstgsr said check ur power steering pump. Also check ur valve cover, headgasket, oil pan and cam gear seals
Old Jan 10, 2016 | 06:34 AM
hugodc2's Avatar
No its coolant guys, its almost teal color cause I aacidentaly mixed the green crap it had with the Honda blue. I'm getting around to flushing it and using only blue...
Anyway, valve cover is fine so is my head gasket. Power steering isn't leaking although my fluid is dirty as hell, I'll get around to doing a pressure test like you guys are saying. If not then I'll just take off the timing cover and check everything in there.
Thanks guys for the help, I'll update if I find anything (:
Old Jan 10, 2016 | 10:00 PM
K20.ek's Avatar
If u say coolant then take ur timing cover off and check ur water pump.
Old Jan 15, 2016 | 06:29 PM
Annapolisintegr's Avatar
definitely a water pump if its coming from the driver side... and you are sure its coolant.
Old Feb 4, 2016 | 09:14 AM
trm4life's Avatar
ooo the bad place, yup its your water pump. Hate to see coolant that side....time for a timing belt! Hooray for you!
flipldls
May 9, 2010 02:14 PM
dth0ng69
18
Jul 19, 2009 09:12 AM
Riptide_NVN
Mar 5, 2009 10:19 AM
acteg94
Feb 10, 2004 05:44 PM
Allstar
Feb 26, 2003 05:55 PM
