suspension question
Old Jan 2, 2009 | 03:37 PM
soto2635's Avatar
Default suspension question
ok right now im riding on ebay coilovers on kyb struts, which is not to bad i was wondering if it would affect the quality if i put aftermarket springs in the front and keep the coilovers on the rear so i can adjust the hieght when i have to carry a load or whatever, the springs are neuspeed by the way. would the be a bad idea or will it work out?? the reason its only the front is b/c the guy im getting them from only has the front springs and hes selling them dirt cheap $20 so i figured why not but i want some feedback on this thanks
Old Jan 2, 2009 | 03:54 PM
FULLYBUILT2.0's Avatar
Default Re: suspension question
too much work...just keep it that way...why put in springs when you already have coil overs. i would understand if you had a full set...haha..
Old Jan 2, 2009 | 08:24 PM
j_bizach's Avatar
if you got the imfamous ebay coilovers itd ditch them asap, ther crap they handle horrible and the ride sucks ull get better performance outta them springs. Are you using your teggy for towing?
Old Jan 3, 2009 | 04:00 PM
soto2635's Avatar
no just i got a lot of fat friends who tend to wight my car down
Old Jan 3, 2009 | 04:19 PM
Targa250R's Avatar
be professional
You do realize that the alignment changes every time that you alter the static ride height, right? If you keep adjusting the height *****-nilly without resetting the toe each time, the car is going to chew through tires like no tomorrow - not to mention handle erratically.
Choose a full set of lowering springs or a full set of coilovers. Half-assing it will only cause more problems than it solves.
Just because something is cheap doesn't mean you have to buy it - especially something as useless as only two lowering springs. I can get XXXXL clothing cheap, but it doesn't fit me worth a damn so what's the point? If you buy on impulse just because something is cheap, then I have a lot of garbage I can sell you . . .
If they were two matching 2.5"-ID coilover springs, it'd be a different story.
Get skinny friends.
Old Jan 4, 2009 | 05:26 PM
j_bizach's Avatar
Originally Posted by Targa250R
Get skinny friends.
So mean LOL. Although I used to hav a larger friend and i told him for every 10lbs he lost id let him "drive my car (93 turbo gsr swap) for an hour. 5 months later he'd lost 48 lbs. a year later hed lost close a 100 lbs. Now i have a skinny friend. I will agree with targa250 your ideas takes your car a bit out of kelter. Hers wat you do; dont be a cheap ahole like most ricers. Save you some money bout 800-1000 get some nice omni coil overs get a weight distribution balance and when u race kick ur buddie out the car. Id imagin by the way u think ur proly trying to race everything with four wheels in which case u shouldnt be endagering the life of ur friend while you do this. if ur just putputing around ur buddies weight shouldnt matter.
matty0234
Dec 6, 2011 04:46 AM
TheEKcoupe
Suspension & Brakes
21
Dec 28, 2009 09:40 PM
boostedhks
Sep 22, 2008 09:50 PM
mars
Nov 19, 2005 08:49 AM
AaronXirisH
Jul 14, 2005 04:31 AM
