RHD Conversion Question??
Old Dec 30, 2008 | 03:44 PM
sk8board{Pete}'s Avatar
Default RHD Conversion Question??
getting a dc soon and I was thinking about doing a rhd conversion. I'm not all that sure on to doing so. I know that I will need the front clip. Is there anything other than the clip i would have to buy in order get the car on the road? Other things like a floor harness, etc...
Thanks in advance!!!
Old Dec 30, 2008 | 09:45 PM
masijdm's Avatar
Default Re: RHD Conversion Question??
why dont you buy one thats already converted:?
Old Dec 30, 2008 | 10:13 PM
what fun would that be
Old Dec 31, 2008 | 12:21 PM
DomesticDestroyer's Avatar
if your looking for a rhd clip and dc shell then my brother has one just let me know
Old Dec 31, 2008 | 12:38 PM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Out of curiousity, did you try searching at all? This has been covered several times, it's a common question really.
If you get the complete clip and I mean complete - then you'll be set.
If you're picking it up piece by piece, you'll need:
- RHD firewall
- RHD rack & pinion
- RHD steering column
- RHD brake hard lines or you can custom bend your own.
- RHD throttle cable or you can rig your own.
- RHD subframe
- RHD clutch/brake/gas pedal assembly
- Dash, headlight/turn signal switch assembly
- RHD Trunk/gas door lever and you'll need to rig the cable for RHD. Unless you want your passenger to pop the gas door for you.
- All the brackets that hold the fuse box, battery tray, and misc brackets that are the opposite of the US.
That should be it. The wire harness can just be flipped over for RHD. If you go with a wire tuck, then you need to undo the wires anyways. The real bitch part would be the brake lines and the firewall. Overall the cost is not too expensive, but the time and work needed is extensive. As you can maybe tell, I was in the process of doing the conversion and I had everything I needed. About midway though the removal of the spot welds for the firewall, I realized that it was a complete and utter waste of my time. Time I could be spending building my car instead of rebuilding my car. So I sold my RHD clip and went on my merry way.
Good luck and remember to use the search.
Old Dec 31, 2008 | 01:14 PM
96teggynonVtec's Avatar
the fun in that would be you saving money. Which would mean using the money for something else.
Old Jan 24, 2009 | 10:43 AM
grey_94LS's Avatar
im in the process of doing a rhd... and i hope that this dont happen to me...LOL... but im starting to see why you gave up on it...LOL... it dose feel like a wast of time at points, BUT should be very cool in the end(and worth it)... GL...
Snailor Built
Dec 19, 2011 11:50 PM
BlueLude 94
Apr 28, 2006 05:52 AM
slowredhatch
17
Jul 21, 2005 10:18 AM
1994hatch
Feb 19, 2004 09:30 PM
BigDaddyRich
Oct 7, 2002 05:51 AM
