NEED Help ASAP
Old Jan 1, 2009 | 02:29 PM
keeblar's Avatar
Default NEED Help ASAP
Hey guys, I wanted to ask if i can get any info on my 95 Gsr.
Well here is the deal, About 2 days ago I was heading to work and I noticed that my car was not letting it get into gear. I was like ummm i dont think it is the sincros because it is not making that rattling noice from the transmission. It lets me get it into gear anywhere from 1-4k rpms anything higher it feels like you have to turn into the hulk to put it into gear. I asked around and people said to check the master cylinder to make sure that there was fluid and if it was leaking. I check it and the levels of fluid and it checked out fine, and also it is not leaking.
So I was like lets move on to another thing.. Could it be the clutch ??? For me checking that I put the car in 3rd gear and let off the clutch alittle to see if it would die.... The car started to move forward alittle so i was like is it the clutch ???? ( I did the same for 5th gear also) Went forward alittle like 3rd. But i also noticed that the clutch petel is all the way to the floor and if i let it out alittle it will grab. The clutch is also not slipping at all it grabs like if it was new... I am really stuck here and i need to get the info asap because i am grinding gears and i dont want to be out 400-600$ for a tranny were i can spend 200 and get a new clutch
Thanks guys..... Keeblar
Old Jan 1, 2009 | 03:16 PM
Jimmy's Avatar
Global Moderator
Default Re: NEED Help ASAP
Have you tried bleeding the clutch? Are you sure you didn't see any fluid leaking near the kick panel around the clutch area (firewall) Have you checked out the slave cylinder?
Sounds like to me you could have a failing clutch disc or pressure plate..
Also Having a more specific thread title will greatly increase the chances of your thread being viewed and you getting help.. rather than ''need help asap''
donepps
Apr 6, 2013 09:36 AM
integracura
Apr 18, 2007 11:18 AM
Luchini
Oct 16, 2005 11:15 AM
CliffBurton
Jun 29, 2005 11:08 PM
