fog light troubles
It seems that from 1990 to present they changed the style connector for H3 fog light bulbs. Now i know this is probably common sense but just in case by some weird coinsidence would the connectors matter with my fog lights not working, and if not where should i look other than, relay(i can here it clicking when i attempt to turn on), Fuse(i checked every fuse under my dash idk about ones under hood), and bulbs. By the way this is on a 1991 Acura Integra LS that has been hit in the front end. Any help would be wonderful.
Pull the bulb, and check for power at the connector with the lights turned on.
If not, keep checking at each point back up the chain.
Hearing a relay fire is meaningless. Checking to see if you actually get power out of it is another story. The multimeter is your friend (and $12 at radio shack if you lack one), so use one.
integraboi1010
Jun 3, 2004 08:23 PM
