Reasonable numbers?
Old Jan 6, 2009 | 04:16 PM
frmdstryr's Avatar
Default Reasonable numbers?
I have a 94 ls with a custom turbo setup. The engine is bone stock, I have stock exhaust (for tuning), evo 19x10x2.5 ic, 2.5in down pipe, 2.5 in ic piping, and a small garrett turbo. The turbo is from a saab 900 16v, it is a TB0356, .42 ar compressor 45 trim, .48 exhaust. I'm running about 11 psi. Here is a compressor map here that I found of the turbo.
http://web.inter.nl.net/users/turbo-...e/compress.htm The stock saab engine made about 175hp at 5 psi (i think).
I'm doing all the tuning myself (rc 440 injectors using crome/wideband). I used my friends iphone's dynalicious program to dyno the car. The iphone said the car has about 260 crank hp, and I estimate that is roughly 220 whp.
My questions, do these numbers seem reasonable? How can my hp be higher than the flow of the turbo?
Thanks.
Old Jan 6, 2009 | 04:32 PM
K i l l a B e e.'s Avatar
Default Re: Reasonable numbers?
that sounds about right actually. .42/48trim turbo @ 11psi should yield ~220
Old Jan 6, 2009 | 04:43 PM
frmdstryr's Avatar
Wow, thanks. I didn't believe it at first. What numbers could I expect with 15 psi?
Old Jan 6, 2009 | 05:06 PM
96teggynonVtec's Avatar
thats probably a too much boost for a stock motor... (although after a second look maybe not since its such a small turbo) Make sure you know what you are doing with all the tuning...
Also why is the exhaust stock?
Old Jan 7, 2009 | 11:17 AM
frmdstryr's Avatar
I've read that 15psi is about the max you can go with stock internals, I've had it up to 20 psi (in which my injectors dump a ton of fuel in so I don't blow it up).There didn't seem like much of a hp increase from 10 to 20 psi but that is probably due to bad tuning (running very rich and no I'm not boosting 20 anymore).
The stock exhaust is on so I can hear if it is knocking or misfiring (and whatever else you can hear), plus it's simply more quiet which is nice for cruising. I have an exhaust, I have just yet to put it on...
Old Jan 7, 2009 | 11:23 AM
the backpressure from the stock exhaiust is horrible for your turbo set up.
Old Jan 7, 2009 | 12:29 PM
frmdstryr's Avatar
How much can I expect to gain from putting the exhaust on? It's 2.5" with a high flow cat.
jackblack22
Nov 3, 2007 11:14 AM
DUB20VT
Jan 30, 2006 10:47 PM
PSI2HI
Jan 24, 2006 05:48 AM
chihuahuamanx
Apr 19, 2005 08:14 AM
jonvo
Oct 14, 2004 08:31 AM
