Code 43 OB1 Issues
Old Jan 4, 2009 | 10:56 AM
dc2money's Avatar
Default Code 43 OB1 Issues
in the past 2 days to work my check engine light came on at the exact same place. doing 40 mph in 4th gear just cruising. checked the code today and it came up as code 43. which is fuel supply systems. i have a 94 LS and lately since gas is cheaper i been putting premium in instead of regular. think that could do it? fuel filter isnt too old, less then 5 thousand miles
Old Jan 4, 2009 | 02:57 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
Default Re: Code 43 OB1 Issues
it ended up being the cat converter in my last DA. it was clogged up and the backed up exhaust was throwing my oxygen sensor readings off. welded in a test pipe, reset the ecu, and it went away after months of trying everything else.
I try and bring this up when I see code 43 threads, because it's one of those things that gets overlooked.
Old Jan 4, 2009 | 08:14 PM
roc0487's Avatar
yo man, my 94 ls is doing the same thing... it sputters at times when I first pull out in 1st, my gas mileage is slowly getting worse and the CEL comes on while cruising. Also while cruising and holding throttle stead, it stumbles. I'm going to get it to the garage this week because I have a huge *** headache from this thing. I'll keep in touch
Old Jan 4, 2009 | 11:45 PM
definitely sounds like the cat converter. mine was doing the same thing. it prob wouldnt hurt to get a new oxygen sensor also if you can spare the coinage, brah.
Last edited by full Circling; Jan 4, 2009 at 11:49 PM. Reason: coinage, brah. coinage.
Old Jan 5, 2009 | 05:51 AM
dc2money's Avatar
hmm i never really thought of it being the cat bc i only have 1 o2 sensor and its in the header before the cat. buttt i have an answer for that because just recently i purchased a test pipe but just been too lazy to put it in. ill do that this week and letcha guys know if it still comes up
FTW_Accord94
Apr 9, 2009 08:39 AM
rorik
Jun 19, 2007 10:13 AM
sickvtec
May 25, 2006 06:58 PM
EFb18b
Sep 17, 2005 07:30 PM
Steemo
May 14, 2005 12:01 PM
