95" Teg Fan Motor for Heater/AC stopped working ????
My fan motor stopped working on my 95 teg today and I'm stuck. Chcked all the fuses and really don't want to tear the dash apart but will if i have too. Does, anyone know if there's a relay for that fan motor, or have any ideas of what I should do....? ADVICE PLEASE...
Re: 95" Teg Fan Motor for Heater/AC stopped working ????
Do any of the fan speeds work at all? Maybe the highest speed? There are wire-wound resistors that step down the current to get the lower fan speeds. These resistors get hot, so they're located right in the air passage of the blower motor housing. There's a 4-pin connector under there somewhere with a single screw holding the resistor plate in place. Sometimes those go bad.
turn on the fan, look up under the pass side of the dash, you should see the bottom of the fan motor, hit it with something, rubber hammer or something that will give it a good wack but won't kill it. Does the fan start working after hitting it?? If so your fan motor is dying and you will need to replace it, if not you probably have another problem but it could still be the motor itself, but they tend to work a few more times if you hit them when they are on the way out, kinda like a starter, same trick applies
stinkbox
10
09-15-2011 02:02 PM
