91 integra
Old Feb 13, 2009 | 11:49 AM
teg_95's Avatar
Default 91 integra
91 integra will not start. it is getting fuel air and has a brand new battery. it will turnover for about 3 seconds then die right back out. i have played with the timming and everything. just will not stay started for more then 5 seconds. anyone have any idea.....
Old Feb 13, 2009 | 02:07 PM
DA3's Avatar
DA3
Default Re: 91 integra
r u getting spark could b a bad coil in the distributor
Old Feb 13, 2009 | 02:56 PM
boosteddohczc's Avatar
ya id check for spark n if that aint it then try the main relay. also turn the key on but dont start it n listen for the fuel pump i know you said you have fuel but just try that. but if there isnt spark then it could be the coil or icm (ignition controle moduale)
Old Feb 13, 2009 | 09:50 PM
teg_95's Avatar
my bad i did mean to put that we are getting a spark. and yes the fuel pumps are priming. we had gas that was in the car for about a year and some change. drained it all at put 93 ocrtane with a fuel booster just so when it mixes with the old nast gas it wont dieloot it to the put where it wont fire. thanks in advanced for the help...
Old Feb 14, 2009 | 11:22 AM
teg_95's Avatar
bump
Old Feb 14, 2009 | 08:16 PM
well did you do anything to it or did it just start doing this. it most likaly is somthing to do with the dizzy like the coil or icm but if you did somthing like change the timing belt then it could also be cam to crank timing. that wouldnt make it not have spark but i still cant tell if you are saying it has spark or not sorry . . . but if it does and it doesnt run then it might b the timing belt timming. also if you didnt just change the timming belt then it could have just been lose or the tensinore could have got lose n skiped some teeth. im not sure im just giving you possibilities. hope that helps
Old Feb 15, 2009 | 09:25 AM
91LsVtecTurbo's Avatar
New User
Have you tried changing your fuel filter?
Old Feb 16, 2009 | 03:40 AM
teg_95's Avatar
its getting spark. my friend bought the car with a rebuilt ls from a friend and the motor and everything was out the car. so we had to put it back in. we were thinking that it was the cam to crank timing. but just havnt gotten a round to it.
will try that and let you know.
Old Feb 16, 2009 | 03:41 AM
teg_95's Avatar
yes it is a new one.
Old Feb 16, 2009 | 08:21 AM
StokelesS_g2's Avatar
Try using "starting fluid".
You may still have moisture in the gas tank. If you do, try a bottle of "Stabil".
Old Feb 16, 2009 | 05:42 PM
teg_95's Avatar
yea we used a little and sprayed some into the itake through the throuttle body. and still nothing.
Old Feb 17, 2009 | 12:15 AM
DA9_DAD's Avatar
I'm not sure if Honda's are prone to this, but I've heard of vapor lock in some cars.
Has the car been sitting out side? if it has, trying removing the spark plugs one at a time and crank the engine so that any residual water gets sucked through. replace the plugs.
Also check to see if there is any red colored residue inside the distributor cap, this is a sign that the distributor itself is failing.
Make sure your spark plug coils are also in good condition.
Test that the fuel line is pumping fuel through, unbolt and remove the fuel line coming from the tank, do a quick or rapid start of the engine and you should see the fuel shoot out of it, you'll know then if your fuel pump is bad.
Old Feb 17, 2009 | 04:48 PM
teg_95's Avatar
done everything above. new plugs. semi new dizzy and cap. took the injectors out and turn the key on and the shot fuel. good spark plug coils
mark3727
Feb 17, 2011 07:01 PM
uptownspeedstar
Jan 27, 2008 09:40 AM
sohc_vtec 2NR
Apr 19, 2007 03:44 PM
nookers
Apr 1, 2004 07:23 PM
