H Brace Install Problem
Old Feb 10, 2009 | 05:56 PM
VietSpeed's Avatar
Default H Brace Install Problem
I was about to install a H brace on my car and ran into a problem. There are 4 bolts, 2 front, and 2 back. The 2 in the front is what connects the front LCA if I am correct. My problem is the bolt that goes through the front LCA looks like it has a nut welded inside the subframe (not sure if its the subframe). but when I unscrew that bolt the nut starts to spin with it and if I do take something and poke it inside the tiny hole and hold the nut while i take the bolt out it might fall in there and i'll be screwed. Does anyone have this problem? And how would I install my H brace now?
Old Feb 10, 2009 | 07:49 PM
chuisek9's Avatar
Default Re: H Brace Install Problem
had the same problem got to cut where the nut is and hold it with a open 17 or take it to the shop and they will cut it and weld it back ..
Old Feb 11, 2009 | 11:22 AM
VietSpeed's Avatar
Will there be a problem if I cut it and leave it like that without welding it back?
Old Feb 11, 2009 | 11:48 AM
PreyStayShun's Avatar
Seems like a lot of trouble to go through for an H-brace my man....I purchased one and ran into the same situation, pitched it to the curb...
Are you looking to reduce body roll & stiffen up the chassis I imagine? Benen makes a front lower tie bar... All in all if your car is lowered you may want to skip the whole concept (really makes for $hitty ground clearance.)
Best of luck to you man!
Old Feb 13, 2009 | 05:15 PM
VietSpeed's Avatar
I just have one laying around and yeah I want to stiffen it up as much as I can. I've got all the Spoon Sport strut bars and I guess this is the last of the add on bars I can put on.
Old Feb 13, 2009 | 05:49 PM
SlammedDC2's Avatar
Semper Fidelis
If you really want to stiffen your chassis up, put in a roll cage. That's the stiffest it will ever be.
Old Feb 13, 2009 | 06:36 PM
VietSpeed's Avatar
Well, besides the roll cage.
Dc2 Strogg
May 28, 2012 05:43 PM
drtysohc
Mar 11, 2008 07:47 PM
jb.
Jan 3, 2005 03:58 AM
VAsol
12
Jan 25, 2004 03:53 AM
delgado200376
Sep 28, 2003 11:42 AM
