Kill Switch for a 98 LS?
Old Feb 12, 2009 | 12:15 PM
meangreenEG's Avatar
Default Kill Switch for a 98 LS?
I was wondering if anybody knew where to obtain a kill switch for a 1998 LS? I keep being told that I should get one.
Old Feb 12, 2009 | 12:18 PM
matt da jdm junkie's Avatar
Default Re: Kill Switch for a 98 LS?
you have to put it in ur self u can get a shop to do it but any hobby shop has switches
Old Feb 12, 2009 | 12:34 PM
seanbev24's Avatar
radio shack, auto parts stores, tons of places to get them.
or, you can use an existing switch/button on your car as a kill switch.
go to the security/audio forum on here and search around there is a bunch of info about what to use and how to wire one.
Old Feb 12, 2009 | 12:40 PM
madriagax619's Avatar
I just had a rocker switch connected to the wires powering the fuel pump.
Old Feb 12, 2009 | 12:58 PM
1SicLS's Avatar
whats that website that has the read up on doing it?
Old Feb 12, 2009 | 12:59 PM
1SicLS's Avatar
http://causeforalarm.thecarthing.com...on6/index.html there u go good info on the kill switch
Old Feb 12, 2009 | 01:04 PM
PreyStayShun's Avatar
http://www.team-integra.net/forum/di...&TopicID=44781
This link is legit...take a look.
Old Feb 12, 2009 | 05:31 PM
215ek's Avatar
x2 on rocker switch into fuel pump wires. just dont put it where everyone else has them... defeats the purpose
Old Feb 18, 2009 | 11:48 PM
LiEkjAi's Avatar
i think all integra owner should invest in kill switch
Old Feb 19, 2009 | 05:52 AM
MD426's Avatar
http://www.pbnation.com/showthread.php?t=2966850
That would be mine
Old Feb 19, 2009 | 08:56 AM
super jdm yo's Avatar
if you just cut the power from to the fuel pump. whoever is trying to steal you car usually will know how that sounds like and just put a constant +12 to the fuel pump directly to get fuel to the motor.
unless you have a really good two-way alarm and all you're trying to do is kill time to get to your car.
Old Feb 19, 2009 | 01:34 PM
noz's Avatar
noz
if i install this will my alarm be off when activate the switch?
Old Feb 19, 2009 | 03:39 PM
MD426's Avatar
It would look very suspicious to pull out the back seat in a parking lot and try to hook up a battery to the fuel pump. Usually people will give up after a while and smash your windows and get some interior things like a head unit or something. Better than the whole car.
Old Feb 19, 2009 | 04:17 PM
DrGrEeNtHuMb's Avatar
Take the wire off of ir starter. Take another wire and put it from the starter to a push button that does not stay on. Then take anotheer wire from the other prong of the button and wire it to a constant 12v. U do that then ur key won't start ur car, it will only turn the cars power on, then u press the button and activate ur starter which starts ur car! Hide the button and ul have another security device, a disabled key ignition and ahidden push button start. Very cool I think
Old Feb 19, 2009 | 04:27 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
DO not do a fuel kill, Perfect reason in the quote above. And one of the reasons that I never install them on any of my installs. Starter kills are a waste of time to on 5 speed. And so is a ignition kill. So what do you do?.......... Locate the main relay of the car. All you have to do is add a 1amp switch to the ground lead to the car. Or add a relay so the alarm can control the main relay. A combination of both will work good if your alarm install is not up to par. Also after you do this its a good ideal to relocate the main relay so a theif can not tamper with it. Reason that this is the best setup for a honda is that there is no way to hotwire the car or bypass it. So this means the car will not be driven away under its own power. This kills the fuel pump, ecu, fuel injectors and parts of the dizzy and sensors on the motor thats needed to run the car. This is very effictive with a stealth alarm install, dei 520t back up battery and well hidden siren. We have a write up comming some on the main relay kill. Please check out the a/s/v of this site.
Old Feb 20, 2009 | 08:50 PM
jdmjoka's Avatar
DB squad #282
great info
integra_101
Jul 29, 2014 07:25 AM
LS_VTECteggy
Oct 18, 2009 09:27 PM
socalrex88
Mar 2, 2008 05:31 PM
StreetRacnGsR
Audio / Security / Video
May 21, 2003 07:49 PM
all stock
18
Feb 14, 2003 04:56 AM
