gsr compression help!!!
Old Feb 17, 2009 | 08:41 PM
lilo_goki's Avatar
Default gsr compression help!!!
okay i just check my compression and it was (1-4) 210 130 210 190, as you can see, the 2nd cylinder is way low compare to the other ones. i tried adding oil in the spark plug hole and it jump up to 150, what do you guys think, is it piston rings, my car is still running very powerful though. also, would it be okay if i just grab a piston that still has ring intact with it and just replace it with my piston, would that be okay without no hone or is there something that is require when installing piston.
Old Feb 17, 2009 | 08:45 PM
94 TuRbO dC2's Avatar
Banned
Default Re: gsr compression help!!!
its def the piston rings... one way or another those rings arent doing their job, just my 2 cents
Old Feb 17, 2009 | 11:05 PM
lilo_goki's Avatar
that's what i'm leaning toward too, but i'm gonna be doing a leak down test this weekend, do you think it'll be okay if i just slap on a used piston with piston rings without doing any work to the block?
Old Feb 18, 2009 | 01:41 AM
wunfstgsr's Avatar
Loved
Community Favorite
noooooo.... just rebuild it if your gonna do that other wise leave it alone it might get worse my 2cents.
Old Feb 18, 2009 | 01:56 AM
lilo_goki's Avatar
well my brother did it like that to his 240sx and compression came back up fine and his car is running fine now.
tobster
Jan 22, 2010 05:10 PM
DC4_MADMAN
10
Aug 23, 2006 08:52 AM
Vpenh
Aug 8, 2006 02:49 PM
Calvinator
Nov 14, 2004 09:28 PM
skunk2eg
Aug 17, 2004 12:10 PM
