Spring release fork
Old Feb 15, 2009 | 08:12 PM
JDMinspiredDA9's Avatar
Default Spring release fork
Regarding transmission problem, My car just didn't go in gear at a red light so I towed it home. Remove the cable transmission and found out the spring that held the throwout bearing, one of the clip broke off.. so only one clip was still on the throwout bearing. I'm referring to part #5, would that cause the transmission to not go in gear?
Opinions welcome. BTW it's a 91 Integra
Old Feb 15, 2009 | 11:19 PM
mandos_sloef's Avatar
Default Re: Spring release fork
just replaced my release bearing and the spring was broken, it also would not go into 1st gear so i think that was the problem.
Old Feb 16, 2009 | 02:52 AM
aznintegraracuh's Avatar
Yes that would create the problem. Could it go into other gears besides one?
Old Feb 16, 2009 | 06:11 AM
It couldn't go into any gears, I would shift into all gears without pressing the shift clutch pedal while the engine is still on.
I will be replacing that spring today and also the pilot bearing, and throwout bearing. The clutch & pressure plate looks good still.
Old Feb 16, 2009 | 08:01 AM
my car would get stuck on 1st and reverse.
Old Feb 17, 2009 | 08:52 PM
dunk'd st@tus's Avatar
Same thing happened to my DA, it doesn't want to go into any gears. First I thought that it might have been my clutch cable because one of my buddies told me that sometimes the clutch cable become loose. So he told me to tighten it which worked for a couple of days, but the problem came back. I really haven't had the time to take the transmission apart; therefore, I haven't really identified the problem, but maybe this can be it.
B18cHatch06
May 9, 2007 09:53 PM
91civicshaw
Jul 31, 2006 11:04 AM
MINT90EF
Jun 24, 2005 11:32 AM
Toxic
Apr 24, 2002 01:15 PM
therealciviczc
Apr 9, 2002 03:19 PM
