mounts...?
Old Mar 10, 2009 | 06:35 PM
teg_95's Avatar
Default mounts...?
so im having a hard time find out the name of the mount that is on the driver side front under the power steering pump, or a/c compressor. and im assuming that the mount on the pass. side that mounts to the sub from or whatever its called is the tanny mount. this is a 94 ls. thanks and if anyone wants to point me in any direction of what to get. shoot for it...
Old Mar 10, 2009 | 07:15 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: mounts...?
There are 2 lower mounts, both called torque mounts. One mounts to the A/C compressor bracket, and the other to a bracket on the tranny. These along with the rear engine mount help keep the engine from rocking fore/aft under torque load, hence the name of the mounts.
Old Mar 10, 2009 | 08:14 PM
redpreludesi's Avatar
geez listen to these moderators their smart.... loving it....you guys seem to be checking these threads alot more i can tell... good work
Old Mar 11, 2009 | 04:04 AM
teg_95's Avatar
thanks. now i couldnt tell but if i buy the innovative set does it come with the torque mounts?
http://www.innovativemounts.com/Prod...ductCode=10150
Old Mar 11, 2009 | 05:23 AM
Toe_Knee's Avatar
Doesn't look like it does...the torque mounts look like the picture here
Old Mar 11, 2009 | 09:28 AM
Community Builder
No, but if those 3 mounts are stiff enough, you don't really need the other 2 torque mounts. I've seen many swaps with aftermarket mounts only run the 3 main mounts.
Keep in mind that the car will vibrate like hell at idle with those mounts. I had polyurethane torque mount INSERTS in my stock broken torque mounts, and even that vibrated like mad while the car was idling. I chucked them after about a week and installed new OEM mounts.
Old Mar 11, 2009 | 09:35 AM
Toe_Knee's Avatar
Patrick, were your torque mounts in 2 separate pieces? Like the middle was separated from the outside rubber? I'm thinking of getting the inserts but not sure if I REALLY have to get new mounts to go with them.
Old Mar 11, 2009 | 09:38 AM
prime_suspect's Avatar
I think this applies to me as well. If I rev high in first or 2nd gear and just left off, the whole car jerks really hard. Do I need new torque mounts?
Old Mar 11, 2009 | 10:03 AM
Community Builder
Yes, my stock torque mounts were completely torn, and yes the inserts can and will fix them. But as I said, vibration at idle was just unbelievable.
I decided to go back with brand new OEM mounts, and also replaced my rear engine mount that was also torn.
So I have a complete set of Energy Suspension inserts for the rear mount and torque mounts for an Integra if you're interested. PM me.
Old Mar 11, 2009 | 06:35 PM
teg_95's Avatar
how do you exactly use the inserts. PMed
Old Mar 11, 2009 | 09:06 PM
Toe_Knee's Avatar
Alright, cool. PMd
Old Mar 13, 2009 | 04:06 AM
teg_95's Avatar
PMd
Old Mar 15, 2009 | 08:03 AM
teg_95's Avatar
so i just order my energy mounts from oriellys with my store cost. when i get them in a do them, do i take the old rubber mount in. or keep that in. i would like to know before the coming Tuesday. thanks
Old Mar 15, 2009 | 10:45 AM
Community Builder
ah damn man, sorry I forgot to get back with ya.
You don't take anything out when using the ES inserts. The inserts only serve to take up the open space in the stock mounts. They're like the reverse of the stock mounts. If the stock mount is a solid and the open spaces in between are voids, then the ES mounts are the solid that takes up the void spaces.
Old Mar 15, 2009 | 04:28 PM
teg_95's Avatar
ok so on my tranny mount the actual rubber oem mount is half in half out. do i just push it back in and put the insert in or do i have to get a oem mount again?
Old Mar 17, 2009 | 04:05 AM
teg_95's Avatar
bumbp
Hyoriu
Nov 28, 2008 09:32 PM
SPD DMN
Sep 20, 2006 01:50 PM
turbo*s2k
Feb 29, 2004 07:46 PM
mingchi69
Feb 20, 2004 08:08 PM
