Distributor ignitors the same?
Old Mar 5, 2009 | 06:52 AM
chevellion's Avatar
Icon2 Distributor ignitors the same?
Are the ignitors for OEM OBD1 and OBD2 distributors interchangeable?
Old Mar 5, 2009 | 07:45 AM
Presidente's Avatar
Default Re: Distributor ignitors the same?
yeah all b series ignitor's are the same.. i know this because i've used a obd2 ignitor on a obd-0 and worked fine
Old Mar 5, 2009 | 09:01 AM
delbert's Avatar
i thought their all the same. even if d-series.
Old Mar 5, 2009 | 10:09 PM
Presidente's Avatar
im not sure on d series never tryed one yet but might work
Old Mar 5, 2009 | 11:12 PM
chevellion's Avatar
Thanks for the info guys.
Old Mar 6, 2009 | 04:12 AM
delbert's Avatar
because everything is exchangable over. from what i thought.
Old Mar 6, 2009 | 05:06 AM
94EG8's Avatar
Seagull Management
All OBD1 and OBD2 D and B-series coils and igniters are all interchangeable.
Old Mar 6, 2009 | 05:52 AM
chevellion's Avatar
Old Mar 7, 2009 | 06:15 AM
NemesisCBR's Avatar
found this on related research and was curious if the part numbers were the same. Comparing a 99 gsr distributor part number for coil and igniter, theyre slightly different for a 94 ls. But i think the only significance is that the gsr part number specifically says p73 to identify which car is normally goes with. The first 5 digits are the same. That said i think Presidente already proved they work so now i gotta see if i can actualy get the ls coil out. Bad screws on a gsr icm i had so i couldnt remove it.
Old Jun 2, 2009 | 09:07 AM
jdm_zam's Avatar
New User
what about the wiring socket on igniter? some have 2 and some oly have 1. I found out this on my frenz car. 1 is using b18c gsr year 94-have 2 socket. n the another using b18c gsr year 95-only have 1 socket. so is it still interchangeable???
Old Jun 2, 2009 | 09:37 AM
TOO MUCH TORQUE's Avatar
even the distributor housing is interchangeable, BUT you need to swap the plugs!!!
Old Jun 2, 2009 | 10:03 AM
jdm_zam's Avatar
New User
oic.....thx for the info...
Joacnel
Engine Management and Tuning
Apr 4, 2012 07:02 PM
ej8_fredi
Mar 28, 2009 11:10 PM
nikkarocky
Texas -OK -LA (Sales)
12
May 3, 2007 10:11 PM
nikkarocky
Apr 10, 2007 12:54 PM
VTECth1s
Jun 5, 2006 04:09 PM
