DA/dc2 traction bar ?
Old Mar 9, 2009 | 02:12 PM
JDMtegg19's Avatar
Default DA/dc2 traction bar ?
does anyone know if my full race traction bars off a 1993 da integra fit on a dc2?
Old Mar 9, 2009 | 03:04 PM
TicketTom's Avatar
Default Re: DA/dc2 traction bar ?
it should if there is any difference it will be the bars connecting to the control arms just do some measuring the center bar should bolt between the two front tow hooks measure that length and the distance from where the trac bars mount from the core support to the lower control arms
Old Mar 10, 2009 | 06:32 AM
JDMtegg19's Avatar
thanks! Ill check that out
Old Mar 10, 2009 | 07:09 AM
TicketTom's Avatar
you can always build your own for around $60-$100 i bought on once and had problem with the hiems joints so i decided to make my own if you have like a fab shop intown they should have all the parts you need and if you need pics on how its setup let me know and i will send you some and even give you the measure ments of my specific set up. btw the other way to preload you suspension this some ksport coilovers or i believe its the tein ss of flex.
aky1234
Mar 3, 2007 02:02 PM
pdotjones
Dec 26, 2006 06:36 PM
JAI-DM
Suspension & Brakes
Jun 15, 2005 03:25 PM
tekstyle
Jul 13, 2004 11:18 AM
jarel
Dec 10, 2003 10:08 PM
