having some abs problems
Old Mar 4, 2009 | 11:19 PM
my_gsr_teg's Avatar
Default having some abs problems
my car is a 95 integra gsr...my abs light is coming on. Everytime i turn on my car the abs makes a weird buzzing sound and after about 15 secs the sound dies and my abs light comes on...any idea or tips on what is the problem?
Old Mar 5, 2009 | 06:31 AM
dc2crzy's Avatar
Default Re: having some abs problems
your ABS pump would be my first guess. If the light is on, can't you hook a scan tool up to her?
In other words, it's probably going to be very expensive to replace.. so just pull it all haha
Old Mar 5, 2009 | 06:47 AM
94_Teggy's Avatar
yeh get it scanned and see what comes up..your abs might be shot..
Old Mar 5, 2009 | 02:01 PM
twentyhurtz's Avatar
? i didn't know you could get it scanned? i have a 95 and mine has been on for 3 years, i just came on here, got the codes and checked them manually just like the CEL's
Old Mar 5, 2009 | 02:10 PM
nanagsr's Avatar
Mines is on too and makes the same buzzing noise I also own a 95 gsr plz let me know you ever fix this problem
Old May 1, 2009 | 07:20 PM
my_gsr_teg's Avatar
i got lazy so i just took out the entire abs..so right now i'm running no abs at the moment
Old May 1, 2009 | 07:47 PM
Dogginator's Avatar
Daisy... Daisy...
You need a paper clip. Pull the ABS codes from the ABS light. The procedure is the same as pulling a cel.
Old May 1, 2009 | 08:03 PM
jdm_bones's Avatar
You could've just had dirty or a bad wheel sensor...you pulled off the whole ABS....wow! You know that it would have been cheaper to diagnose this! Good luck trying to have ABS again, it going to burn a hole in your wallet....
Old May 1, 2009 | 09:53 PM
my_gsr_teg's Avatar
i checked the code thing a while back it was the abs pump motor over-run
Old May 2, 2009 | 05:50 AM
Dogginator's Avatar
Daisy... Daisy...
IIRC, the internal valve could be leaking, thus draining the high pressure. i'll have to check the Helm manual later.
jp1racer
Dec 22, 2010 08:12 AM
badboiz530
Jul 17, 2007 06:51 AM
iLUVmyACCORD
Jan 6, 2005 04:49 PM
meat
Jul 30, 2003 08:56 PM
Audio28
Dec 22, 2002 11:48 PM
