Compression Problem
Old Mar 5, 2009 | 01:37 PM
EFSedanMan's Avatar
Default Compression Problem
soooooo i just tested my comp. in all cylinders...i did the usual 8 cranks and i got 77-78-85-75. Obviously there is something wrong...i dont know where to start here. I dont want to jump straight to the impression that my rings are blown...but i know its a possability. Im also still in high school so im on a tight budget. Can you guys help me out here?? any help would be greatly appretiated.
heres the specs:
96 Integra LS
155k
B18B1
no mods just an intake but that doesnt really matter.
thanks guys.
Old Mar 5, 2009 | 03:58 PM
seanbev24's Avatar
Default Re: Compression Problem
It's pretty rare that you'll have such even numbers that are so low. Usually if you have problems you'll see low compression in like 1 or 2 cylinders, but not all 4 like that. The only thing I can think of is it's out of time like the belt skipped teeth or something so your valves aren't closing all the way.
Are you sure you did the test right? A lot of people don't realize that it need to be at WOT when doing the test, either by flooring the gas pedal or doing it at the throttle body.
Does this car run? If so, do the test when the engine is warm.
If you did the test right, and your timing is right, do a leakdown test to pinpoint the issue.
Old Mar 7, 2009 | 08:02 AM
EFSedanMan's Avatar
aaaahhhhh thats why. i completely forgot i had to do it at WOT. thanks man.
Old Mar 7, 2009 | 11:33 AM
seanbev24's Avatar
no problem, a lot of people forget about that
Old Mar 7, 2009 | 12:31 PM
racebum's Avatar
the gauge is also suspect with numbers like that and a good running car
umair
Dec 7, 2009 10:37 AM
gs-R_swap
Oct 4, 2009 12:12 PM
boosted_lude
Jan 27, 2006 09:31 AM
92siracer
Jun 2, 2004 10:29 PM
piscorpio
12
Apr 28, 2003 05:10 AM
