window problem
Old Mar 8, 2009 | 10:40 PM
julianbc2's Avatar
Default window problem
my 94 ls front windows raddle when i shut the door when the window is open and raddle while the window is open. how do i fix this problem?
Old Mar 9, 2009 | 01:53 AM
imroadk1ll's Avatar
Default Re: window problem
mines only rattles when im on the highway i think you just gotta tighten something not too sure since mine slightly rattles wen im on the highway
Old Mar 9, 2009 | 03:51 AM
fear the -vtec-'s Avatar
New User
yea my 95 gsr does the same, particularly if i go over bumps. Mostly only on passenger side tho
Old Mar 9, 2009 | 05:47 AM
safedriver's Avatar
I read a thread, about this. Get a flashlight, roll up the window, take off the door panel, reach in and feel around for a rubber strip that has fallen off (the rear vertical track).
Feel for the vertical track and then wipe it off. Practice putting the rubber strip in place, a couple of times. I can not remember if the notch on the rubber strip, goes up or down, but by trying it a few times, you can determine if the window will knock it back off (when rolled down).
Now that you know how it fits, you can use a little silicone, to keep it in place.
While you have the door panel off, spray some silicone in the front and rear window tracks. This will help your window roll up faster.
Old Mar 9, 2009 | 01:27 PM
imroadk1ll's Avatar
thanks ill try and do this, i just hate putting the door panels back its really hard
PatrickGSR94
Jan 5, 2008 07:47 AM
i-want-a-crx
Oct 13, 2007 08:41 AM
Silverdot
Jun 24, 2006 04:42 PM
C2daIzZle
16
Sep 9, 2005 05:06 AM
hott-nix
Apr 3, 2005 04:04 PM
