ls vtec problems
Old Mar 10, 2009 | 05:10 PM
towter100's Avatar
New User
Default ls vtec problems
hey i got an ls vtec and i had the usual idle air valve problem, cleaned it out and adjusted the idle screw and now the engine rpm fluctuates up and down between 1000 and 1500rpm, but after that everything runs smooth, has anybody had this problem before or does anybody have any suggestions? thanks. by the way it has a p14 ecu
Old Mar 10, 2009 | 07:00 PM
MumBleZ_94gsR's Avatar
Default Re: ls vtec problems
throttle body maybe...take off ur air filter and see if ur trottle body is sucking on air from the holes and if it is put ur finger on it and see if it idles fine after that
Old Mar 10, 2009 | 07:07 PM
ef8 king's Avatar
New User
my ls vtech was doing the same i cleaned the throtle body and i installed a fuel pressure regulator and i never had a problem. o and did any one have a prob with there rpm gauge it wont work ever since i did the swap
Old Mar 10, 2009 | 07:36 PM
tn_90's Avatar
New User
YOu should get it checked out by a professional if nothing you try works.
keons5
Aug 16, 2009 07:52 AM
ninthgatemotorsports
Apr 2, 2009 06:58 PM
vtecda
Aug 15, 2005 07:41 AM
delsol1225
Jun 13, 2004 11:48 AM
sk8phaze
Aug 16, 2002 10:45 AM
