GSR misfiring?
GSR misfiring?
My 95' GSR is misfiring and is definitely on 3 cylinders.
Recently replaced
-Distributor OEM
-Spark Plugs NGK
-Spark Plug Wires NGK
-O2 sensor NGK
-TPS sensor NGK
compression was 180-180-180-170
Theres black soot on my rear bumper and coming out of my exhaust, which i thought is unburnt fuel. I can't figure out why my car is misfiring. My car is throwing no CEL's. Checked CAM timing. What else can i check?
Recently replaced
-Distributor OEM
-Spark Plugs NGK
-O2 sensor NGK
-TPS sensor NGK
Re: GSR misfiring?
I'm guessing its somewhere in the ignition system thats messed up or something, throwing no codes. I wonder if the ICM in the distributor is bad ?
Re: GSR misfiring?
yeah, it was an OBD2 - but i repinned it to obd1 plugs and it ran fine afterwards. Started misfiring now though. I'll try swapping the ICM's and see if it fixes the problem. I'll update this thread in the evening probably
