91 da with startin problems help
Old Mar 8, 2009 | 10:45 PM
vdawg559's Avatar
Default 91 da with startin problems help
okay...... here wats wrong wid it..... if i was to start up the car, it would start, an s tay at normal idle an wont die....but once i turn it off, it wouldnt start right back up again.
if i wait for 10-15 minutes or push start, it would start right bac up again.
i havent change anything. cus i just bought the car. i didnt wanna b a parts changer so im askin honda-tech for info on this problem. heres another problem. when i try to start it. an it wouldnt start. the car would turn over, an dies quickly.... soooooo....
could it b the ign coil, control module, or main relay? or even fuel pump? mayb even dizzy?
if some one has fix this similiar problem, let me know.
Old Mar 8, 2009 | 11:49 PM
TheHypnotic's Avatar
Default Re: 91 da with startin problems help
How's the idle while running and right before it dies? Might be a number of things. Could you be a little more specific? Have you adjusted or replaced anything lately?
BTW, I kind of got what you were trying to say. Although, not to sound like a *****, the bad english didn't help.
Old Mar 9, 2009 | 01:40 AM
vdawg559's Avatar
sry bout that bro. i just fix it. plz re read.. you probly had the same problem before. an i might need the info to fix my car.
Old Mar 9, 2009 | 07:03 AM
89canefighter's Avatar
im having the same problem also. Buth times it has happened to me is on short stops. When it happens the car starts up fine idles about 1200rpms then starts falling to regular rpms but falls on its face and dies giving it gas is no help either. When it happened both times i poped the hood made sure all the wires had tight connections with the plugs and dizzy cap then started right up. So im thinkin a spart issue but it could be a fuel pump issue. The cap and rotor are new i sold them to my friend when he did them (i just bought the car from him) so im rolling that out might be the coil or ig module
Old Mar 9, 2009 | 02:09 PM
worrx's Avatar
whats the temperature like? is it hot in your car? are you driving with the heater on?
what is very common in the G2s is the main relay. if the car gets hot inside they malfunction. what i did was when it happened to me one morning i took the relay out and threw it in the fridge for 10 mins plugged it back in and it started up so i knew it was the main relay. i have since then replaced it with a new one from the dealer and have yet to have the problem.
hope that helps.
kevin
7andaswitchblade
May 26, 2009 08:10 PM
jdmkrazie
Jun 16, 2004 08:42 AM
dubracr18t
Aug 25, 2003 08:08 AM
tmekjian
Jul 28, 2003 04:53 AM
