whats the diffrence between this short shifter??
Old Mar 4, 2009 | 09:27 PM
ptown909's Avatar
Default whats the diffrence between this short shifter??
i see the skunk2 shortshifters for 110$ and then i see some aftermarket ones for like 30$ or cheaper...
are all shortshifters the same or skunk2 makes there different??..
or is just the brand im buying..?
Old Mar 4, 2009 | 09:40 PM
JabberwockySuperfly's Avatar
Default Re: whats the diffrence between this short shifter??
To a certain point you're buying the name, you're also paying for a better quality product, I've seen cheaper "eBay" shifters break though. When you buy a name brand product you're buying the R&D that comes from a real company, sooner or later the more knock offs that get bought the more real companies that will go out of business. After that there will be no after market and therefore nothing to knock off, that's why I always buy the real deal, it's worth it to keep the products coming.
Old Mar 4, 2009 | 09:57 PM
Gant's Avatar
just get the skunk2
Old Mar 4, 2009 | 10:39 PM
IntegraCF21's Avatar
I really wouldn't trust an eBay short shifter or any aluminum one for that matter. They have a high tendency to break from what people say on various forums. Just go with the tried and true Skunk2 and not have anything to worry about. Cheap stuff usually means cheap quality so you will eventually have to replace it when something goes wrong later on and spend just as much money in the end.
Old Mar 4, 2009 | 10:46 PM
OOOtony's Avatar
ON SALE! i already got mines GET THIS **** WONT BREAK LIKE SHITTY EBAY
http://store.summitracing.com/partde...5&autoview=sku
Old Mar 5, 2009 | 01:29 AM
BlueIntegraBoy's Avatar
Skunk2 uses steel and is heavier and stronger than the cheap eBay aluminum shifters. There are other alternatives to Skunk2 such as MFactory (pretty much the same as Sk2) and Buddy Club. Both use steel.
Old Mar 5, 2009 | 02:45 AM
94VTEC2TONE's Avatar
i used an ebay shifter for 6 years didnt break at all. then went to skunk2 and theres no difference
Old Mar 5, 2009 | 02:57 AM
ilvi3tkidxx's Avatar
i hate the skunk2 one.. but my friend likes it.. havent broken yet... id stick to jus stock regular integra shifter etc..
Old Mar 5, 2009 | 06:35 AM
dc2crzy's Avatar
a friend of mine broke an ebay shifter switching into third gear a little to ohard apparently haha. I would go with Skunk2 or B&M, both quality. Skunk2 comes with the name.
Old Mar 5, 2009 | 06:44 AM
94_Teggy's Avatar
the skunk2 his heavier..better to throw into gears.spend the money and get the good one..not the cheapo ebay one
Old Mar 5, 2009 | 01:06 PM
OOOtony's Avatar
your ebay shifter hasnt broken yet becasue you been granny shifting when you should be power shifting your allmotors
Old Mar 5, 2009 | 01:35 PM
Nataku's Avatar
And not double-clutching like he should
Old Mar 5, 2009 | 01:52 PM
twentyhurtz's Avatar
i use a B&m short shifter, about $50 bucks
Old Mar 5, 2009 | 01:54 PM
OOOtony's Avatar
Originally Posted by nataku
and not double-clutching like he should
lol
Old Mar 5, 2009 | 04:40 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Skunk2 shifters are nice. But I have an AutoZone $40 short throw that I bought nearly EIGHT YEARS ago and I've never had a single problem with it. And yes, I have done my fair share of hard shifting. The shifter height is the same as stock, but the throws are much shorter. It has metal bearings in the bottom, unlike other POS shifters (B&M included) where you have to re-use the stock rubber crap from the stock shifter, which makes the shifter feel sloppy.
Most of the time I've used shift ***** that attach with set screws below the threaded portion of the shifter, which I'm sure helps prevent the shifter from breaking. But right now I'm using my stock shifter on the threads and still no problems.
Old Mar 5, 2009 | 05:25 PM
jhammond_82's Avatar
Reject Papi
this is the third "short shifter" thread in two days. search and you will find billions of threads on this topic.
Old Mar 5, 2009 | 08:57 PM
itotech's Avatar
B&M I had it worked great..If you get a weighted shift **** like Blox/Skunk2 you'll really feel the diffrence
Old Mar 5, 2009 | 09:53 PM
rebar71's Avatar
I will throw TWM Performance's name into the hat as well. I have a shifter/**** combo from them and it is exquisite.
jonnyt1130
Transmission & Drivetrain
Oct 6, 2009 07:14 AM
teg_dc2
Mar 6, 2009 04:01 AM
wolf95
16
Feb 10, 2008 01:28 PM
98exturd
11
Nov 11, 2007 03:58 PM
wc
Jul 23, 2002 05:01 PM
