Driver side Headlight Out!?!?
Old Mar 8, 2009 | 04:49 PM
naler62188's Avatar
Default Driver side Headlight Out!?!?
Ok, I just replaced my cv axles, transmission, clutch, flywheel, and pressure plate. I get everything together drop it drown, start it up... Perfect. I back out of my driveway turn on my lights and notice my driver side headlight was out. I had just taken out my hids and put back in regular lights, I figured the light was blown. I hook up my HID and it doesn't work, I put in a light that I knew worked and still, nothing. I checked my fuses, all of them are fine. What the eff?
Old Mar 8, 2009 | 06:09 PM
webbs2jzgte's Avatar
Default Re: Driver side Headlight Out!?!?
did you check all the gorund on the harness. and their might be a short in that pigtail
Old Mar 8, 2009 | 08:10 PM
97gsrTS's Avatar
check your grounds and wiring on the harness.
Old Mar 9, 2009 | 12:08 AM
TheHypnotic's Avatar
Use a DMM (digital multi-meter) and check to see if there is any voltage coming to the pigtail on the harness. If anything work your way back to the source.
ED6Jr
Apr 9, 2018 08:21 AM
pgpunkguy
Dec 24, 2005 04:29 AM
crx2ner
Sep 13, 2005 07:45 PM
Dacalac
Jul 11, 2003 03:28 PM
