ABS Makes Noises
Old Mar 6, 2009 | 02:35 PM
uses0ap's Avatar
Default ABS Makes Noises
i have a 94 integra and went the car is idling, ever so often, (i think its the ABS) makes a sound and vibrates for about a second..
anyone have any ideas why or what might be wrong?
thanks
Old Mar 6, 2009 | 03:37 PM
soto2635's Avatar
Default Re: ABS Makes Noises
mine does the same thing
Old Mar 6, 2009 | 06:50 PM
dvs94Teg's Avatar
From: NORCAL Salinas Valley to Monterey Bay Area 831 CA
Same here. I think its normal.
Old Mar 7, 2009 | 08:35 AM
whitengolddc2's Avatar
is your abs light on? there is a tsb on the abs system for 94+ integras. check the fluid level and add if needed, or try bleeding the system.
Old Mar 7, 2009 | 08:47 AM
DC206R's Avatar
yeah, if ur abs light is on, then maybe its low on fluid. other than that the noise is normal, Mine does it too. Its jsut the pump pressurizing.
Old Mar 7, 2009 | 01:40 PM
uses0ap's Avatar
abs light is not on...fluid level is fine
Old Mar 7, 2009 | 02:29 PM
DC_Legacy's Avatar
Thats the sound of a stepper motor within the ABS unit working to keep the pressure in your brake system within a certain range. As long as your ABS light is off, or your not having any braking issues I'd say your fine.
Generally you'll hear this after starting your engine or briefly during idle.
Old Mar 8, 2009 | 03:30 PM
dvs94Teg's Avatar
Old Mar 8, 2009 | 07:45 PM
jdmjoka's Avatar
DB squad #282
mine doesnt do it but my buddy's does. weird its cool sounding tho!
Steve LeB
Feb 10, 2011 02:58 PM
rickyh22
Oct 9, 2007 03:00 PM
Vagabund07
Oct 7, 2007 06:06 PM
KingJeff
Apr 29, 2002 05:08 PM
