S-AFC Hack won't lean out!?
Old Apr 11, 2003 | 08:33 AM
spooler's Avatar
Default S-AFC Hack won't lean out!?
I have the S-AFC hack, 450cc injectors and 11psi (t25) on a 94 Integra LS and the wideband is still reading rich in all ranges with it all the way down to -50%!? Any ideas what is wrong?
TIA
Old Apr 11, 2003 | 08:42 AM
Tony Starks's Avatar
Default Re: S-AFC Hack won't lean out!? (spooler)
Whats it idle/run like at -50%?
Old Apr 11, 2003 | 09:11 AM
spooler's Avatar
Default Re: S-AFC Hack won't lean out!? (Tony Starks)
It idles fine and normal driving is fine, just the in boost condition go extremely rich.
Old Apr 11, 2003 | 09:31 AM
1bar's Avatar
whats ur fuel pressure set at?
Old Apr 11, 2003 | 10:20 AM
ASDspeedshop.com's Avatar
Default Re: S-AFC Hack won't lean out!? (1bar)
11psi.
Old Apr 11, 2003 | 10:22 AM
RAWB's Avatar
Default Re: S-AFC Hack won't lean out!? (ASDspeedshop.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ASDspeedshop.com &raquo;</TD></TR><TR><TD CLASS="quote">11psi.</TD></TR></TABLE>
Old Apr 11, 2003 | 10:43 AM
spooler's Avatar
Default Re: S-AFC Hack won't lean out!? (RAWB)
We have the stock fuel pressure regulator and the stock pump. Do these need to be upgraded? What about using a filetofit chip and also using the S-AFC on top of that?
Old Apr 11, 2003 | 10:47 AM
swlabhot's Avatar
Sure u got your AFC set for both LVT AND HVT for both Narrow AND wide throttle correctly?
Old Apr 11, 2003 | 11:59 AM
spooler's Avatar
Default Re: S-AFC Hack won't lean out!? (swlabhot)
Can you expand on those settings please. I cannot even find those settings in the Apexi S-AFC.
In reply to the "11psi." post, what do you mean by that? Can I not run that much? That post didn't make since to me.
Old Apr 11, 2003 | 12:03 PM
b18bturbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooler &raquo;</TD></TR><TR><TD CLASS="quote">Can you expand on those settings please. I cannot even find those settings in the Apexi S-AFC.
In reply to the "11psi." post, what do you mean by that? Can I not run that much? That post didn't make since to me.</TD></TR></TABLE>
11psi static pressure is way low usually most factory pumps and regulator run around 38-42psi base pressure.
Old Apr 11, 2003 | 12:16 PM
spooler's Avatar
Default Re: S-AFC Hack won't lean out!? (b18bturbo)
I meant 11psi boost if that wasn't obvious aside from the fact that the car would most likely lean out instead of being rich if I only had 11psi fuel pressure. I don't think the car would even run actually.
Old Apr 11, 2003 | 12:26 PM
legendboy's Avatar
sounds like its hooked up wrong, theres no way your car would idle fine at -50%
rhdjitsu
Mar 22, 2006 06:10 AM
Johnny_Rocket
Mar 2, 2005 10:03 PM
dc-lefty
Mar 10, 2004 10:38 PM
Hoodwinked
Sep 3, 2003 08:30 PM
Jamison
Jul 9, 2002 03:44 AM
