SOHC guy's - help with settings for Ubers boostchip
Hey fellow loyal sohc'ers.
I just want to put a post up to get some thoughts from you all on my setting for my uber boost chip.
It goes alittle some thing like this:
1. engine - D16Z6
2. ecu (p28)
3. injector size in cc - 450cc
4. map sensor type - stock honda
5. turbo - TD05-14b
6. desired vtec xover ? (should I even change this at all? from 5500 to 5300 maybe?)
7. desired rev limit - 7500
8. desired launch limit - 3000
So what do you think guy's? I'm using only street tires so I figure the 3k launch should do it.
Comments/suggestions please. Then I'll take ya all out for a
1. engine - D16Z6
2. ecu (p28)
5. turbo - TD05-14b
Re: SOHC guy's - help with settings for Ubers boostchip (Hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid »</TD></TR><TR><TD CLASS="quote">Hey fellow loyal sohc'ers.
1. engine - D16Z6
2. ecu (p28)
5. turbo - TD05-14b
I say it looks good. Although I thought VTEC crossover was 4600-4800?
I switched mine to 4400 though. Good luck.
1. engine - D16Z6
2. ecu (p28)
5. turbo - TD05-14b
Re: SOHC guy's - help with settings for Ubers boostchip (ladysman)
My vtec engages at 5500, I figure dropping it to 5300 Should be signigifant. Some time you make more power by doing this, other times you don't, so I'll play it say by dropping only a couple of hundrer rpms.
deemack79
15
05-13-2004 05:34 AM
