Nitrous on hold!?
Old Apr 11, 2003 | 03:05 PM
xstalkrx's Avatar
Default Nitrous on hold!?
Ugh...did compression test on my 90 ls teg a few days ago. All cylinders were cool, like 180-190 across the board. Then I pull out the last plug wire, and the plug was surrounded in oil. This pretty much tells me why I'm getting a small oil leak in my bay. But anyways, I don't get any black smoke out my exhaust, EVER. So, I was thinking maybe this is just a gasket? Car has 130xxx miles on it. The compression on that cylinder was like 220. Is this cylinder firing or if it is firing, would it not be firing very well? I can't go nitrous with the compession in that cylinder out of wack. Im planning on a conservative 50 shot.
Old Apr 11, 2003 | 03:42 PM
xstalkrx's Avatar
Default Re: Nitrous on hold!? (xstalkrx)
Old Apr 11, 2003 | 11:38 PM
sporkcrx's Avatar
Where on the spark plug is the oil? If it's on the top, it's probably just the circle gasket for the valve cover, if on the bottom that's bad...but I don't think the compression would be so high w/ leaking rings or valve seals...unless the oil is sealing it
nengx07
20
Feb 6, 2009 08:10 PM
grundle
Aug 10, 2007 07:14 PM
xstalkrx
Apr 12, 2003 09:39 AM
xstalkrx
Mar 5, 2003 02:39 PM
