ls drag 3 install
Old Apr 10, 2003 | 04:50 PM
InTeGrA B18b1's Avatar
Default ls drag 3 install
i have the drag mani,drag dp, and t3/t4oe turbo from a drag kit. my question is what do i have to modify on my car to make it fit. i have heard that i might have to drill the block for room for the turbo. Can anyone tell me about there drag turbo installs on a integra ls? thanks for the help
Old Apr 10, 2003 | 04:58 PM
Default Re: ls drag 3 install (InTeGrA B18b1)
any info would be nice
Old Apr 10, 2003 | 05:03 PM
Ben Huynh's Avatar
You may or you may not have to shave your block slightly to clear the E trim turbo. You'll have to get a flange welded on to the downpipe if it doesn't already have one. The rest of the parts are bolt-on.
Old Apr 10, 2003 | 05:08 PM
Default Re: ls drag 3 install (ben@importparts.com)
i was looking at other people and they had to shave there block. you think i have to move like the fans or cut anything? thanks for the help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ben@importparts.com &raquo;</TD></TR><TR><TD CLASS="quote">You may or you may not have to shave your block slightly to clear the E trim turbo. You'll have to get a flange welded on to the downpipe if it doesn't already have one. The rest of the parts are bolt-on.</TD></TR></TABLE>
Old Apr 10, 2003 | 05:10 PM
Ben Huynh's Avatar
Whether you have to shave the block varies from car to car. You will also have shave down your fan or get a slim fan.
Old Apr 10, 2003 | 05:17 PM
is there a for sure answer if i have to shave my b18b1 ls block to fit the turbo?thanks
Old Apr 10, 2003 | 05:20 PM
Teg4e's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InTeGrA B18b1 &raquo;</TD></TR><TR><TD CLASS="quote">is there a for sure answer if i have to shave my b18b1 ls block to fit the turbo?thanks</TD></TR></TABLE>
You'll find out when you try to fit on the manifold and turbo. Even with my t3/t04b (54 trim), I had to significantly shave the block, cut deep into the fan housing, and trim the blades. Nothing terrible, but it does take time.
Old Apr 10, 2003 | 05:25 PM
SIK IN DA HED's Avatar
New User
Default Re: ls drag 3 install (Teg4e)
it really does depend. my fan shroud didnt have to be modified at all.
Ben Huynh's Avatar
Yes it's a fairly painless operation.
Old Apr 10, 2003 | 05:29 PM
Default Re: ls drag 3 install (SIK IN DA HED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIK IN DA HED &raquo;</TD></TR><TR><TD CLASS="quote">it really does depend. my fan shroud didnt have to be modified at all.</TD></TR></TABLE>
did you shave you block?did you move the compressor or anything? what was the most complicated part of your install?
thanks man
sfwdcrx
Mar 19, 2008 02:33 AM
vestalfootball72
Jul 31, 2007 10:12 AM
civicb18Tkid
Mar 16, 2007 11:13 AM
gsrboost
May 5, 2005 09:14 AM
Gfunk176
Mar 5, 2003 08:07 PM
