JRSC bypass?
Old Apr 10, 2003 | 04:21 PM
Tiamat-blue's Avatar
Default JRSC bypass?
I know this is probably a stupid question. What would happen if I removed the boost bypass from my JRSC'd 99 civic dx? How bad is boost at idle? I only ask this because the used kit I just bought seems to have a broken bypass valve.(I haven't installed it yet but reeeeaaaaallllly want to) I'm waiting to hear back from Jackson to see if they sell them seperately.
Old Apr 10, 2003 | 04:30 PM
MachAF's Avatar
Default Re: JRSC bypass? (Tiamat-blue)
you'll put a lot of stress on your engine. Boost at idle = bad.
Old Apr 10, 2003 | 05:40 PM
Default Re: JRSC bypass? (MachAF)
What if I left it partially open? All the time. Untill I got the new one?
Old Apr 10, 2003 | 05:47 PM
jabroni95gsr's Avatar
how do you know its broken>? what does it look like? i forget...
Old Apr 10, 2003 | 06:02 PM
Default Re: JRSC bypass? (jabroni95gsr)
It's the black plastic "can" that opens the bypass throttle body under vacuum. Inside, as far as I can tell without breaking it open, there's a rubber seal, and some kind of spring. And a rod that conects to the bypass TB. The point inside the valve where the rod attaches to is broken off. Leaving a hole, and no pull on the rod when under vacuum. There's also a small tear in the rubber seal. So again no vacuum. Just a nice leaking whistleing noise when I hooked it up to see if it would work.
If I leave it partially open, with 0 boost at idle, would I still have a little boost at throttle?
I haven't installed the SC yet and was really hoping to this weekend. Since I may not have time to next weekend.
Old Apr 11, 2003 | 03:17 AM
ttt
Old Apr 11, 2003 | 05:58 AM
fredtoast's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tiamat-blue &raquo;</TD></TR><TR><TD CLASS="quote">What if I left it partially open? All the time. Untill I got the new one?</TD></TR></TABLE>
Then you wouldn't have boost at anytime.
Old Apr 11, 2003 | 06:44 AM
JT's Avatar
JT
After removing the valve, you can simply zip tie the bypass butterfly plate open and the engine would just run like normal and perhaps a max. of .5 psi of boost during WOT.
Old Apr 11, 2003 | 11:59 AM
Default Re: JRSC bypass? (JT)
That's what I was hoping.
Old Apr 11, 2003 | 12:05 PM
greekspeed's Avatar
jackson does sell all parts individually (if u havnt found out yet). u just have to figure out what the item number is and call it in to have em send it to u.
Old Apr 11, 2003 | 12:26 PM
92sleepR's Avatar
New User
Call JR directly. They should be able to sell you that part no problem. Dont bother trying to install it untill you get a working one. It would be next to impossible to swap it out once the SC in on the car. Trust me on that one.
Mike
blakkvtec
Aug 18, 2009 07:13 PM
quik1
May 3, 2004 07:39 AM
Built B16A
Apr 5, 2004 06:15 AM
94jaxgsr
Jul 20, 2003 08:16 PM
B_1_8_hatch
Apr 14, 2003 02:10 PM
