recommended motor build for sc
Old Apr 13, 2003 | 01:13 PM
jmcfkya's Avatar
Default recommended motor build for sc
I would like to know some good products to build a gsr motor to safely boost about 12psi from a supercharger. I don't want to have any problems, blow any gaskets or blow my motor. I want it to be strong so I don't have any worries. thanks. Also what's a good compression piston to use............. thanks.
Old Apr 13, 2003 | 01:49 PM
CRVRX's Avatar
Default Re: recommended motor build for sc (jmcfkya)
I would put pistons , rods in and a set of ARP head bolts and you'll be fine.
Try and stay around 10-1 compression , once tuned it will live forever.The rest is just bolt ons to make good power.
Old Apr 13, 2003 | 02:47 PM
MotorMatrix.com's Avatar
I am a bad person
[QUOTE=jmcfkya]I don't want to have any problems, blow any gaskets or blow my motor. QUOTE]
then keep it stock!! once you go FI you will have a high chance of all of the above.
Old Apr 13, 2003 | 02:50 PM
CRVRX's Avatar
Default Re: recommended motor build for sc (MotorMatrix.com)
That is also true , You buy a Honda and leave it alone it will run for forever. Make it go faster and you will never quit working on in some way or another
Old Apr 13, 2003 | 02:52 PM
jmcfkya's Avatar
Default Re: recommended motor build for sc (CRVRX)
nevermind, you people don't answer questions...............
Old Apr 13, 2003 | 02:59 PM
CRVRX's Avatar
Look at my post, That will anwser your question . I have run cars at 10 psi and tuned them and they never come back.
Once you make the car faster , you want to keep going faster. Then it will break , then you have to make it stronger so you can keep making it faster. That was just making light of the sport.
dailyekhatch
Nov 13, 2009 07:16 AM
Bonestock98GS
Apr 9, 2009 07:43 PM
Scubster
Dec 16, 2004 10:54 PM
anothersickhatch
May 27, 2004 08:55 AM
broncoman74
Jun 2, 2003 02:12 PM
