anyone here have a single fan radiator on an integra
Re: anyone here have a single fan radiator on an integra (94goldjungsr)
I've got a civic radiator in mine but I had to gheto rig the ****. Here's a link to some pics...
http://www.horsepower411.com/f...did=4
I'm going with a fluidyne very soon and I plan on fabricating a lower bracket for the bump stops on the bottom of the radiator to fit into, then I wont have to use those stupid brackets up top.
Re: anyone here have a single fan radiator on an integra (Diego Boost)
Can you keep the AC with the 1/2 sized rad on an Integra? What do you do with the second fan?
Re: anyone here have a single fan radiator on an integra (RAWB)
I have a PWR Civic radiator in my Teg. I drilled out the stock mounts and then riveted them back in at new locations.
1 Post
i have only one aftermarket fan on my integra. I shut the AC side off because it was rubbing and havent had the time to fix it. actually its been off for a while now. now problems with overheating or anything.
The aftermarket fans were from pepboys and they include everything u need to mount.
Re: anyone here have a single fan radiator on an integra (Farnsrocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Farnsrocket »</TD></TR><TR><TD CLASS="quote">I have a PWR Civic radiator in my Teg. I drilled out the stock mounts and then riveted them back in at new locations. </TD></TR></TABLE>
can you describe this some more please
Re: anyone here have a single fan radiator on an integra (Cramerox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cramerox »</TD></TR><TR><TD CLASS="quote">i have only one aftermarket fan on my integra. I shut the AC side off because it was rubbing and havent had the time to fix it. actually its been off for a while now. now problems with overheating or anything.
I've got the same thing going on - no A/C fan with no troubles. I figured I'd run it for a while and see if I can into any cooling problems, but I never did, so I never bothered to replace it
Re: anyone here have a single fan radiator on an integra (johnisenglish)
This is not the best pic, but here is a shot of my radiator remounted. I just drilled out the 4 spot welds that hold each ot the two original bottom mounts, and then riveted them back in at different location on the front support of the car.
IntegracinGSR
02-03-2004 04:51 AM
