In what intervals are tial springs available? 10psi?
Re: In what intervals are tial springs available? 10psi? (BoostedGSRBubble)
Most online shops can order them, or anybody who carries tial products.
You will need the .65 bar spring, that will get about 9.5psi..
.35 bar
.45 bar
.65 bar thats all i know
.35 bar
.45 bar
Re: In what intervals are tial springs available? 10psi? (b16ahybrid)
Thanks. I just found the tial website, tialsport.com. Im kinda torn between .65 and .8 springs. The .8 is 11.somethin lbs. Would anybody else run this on a stock gsr block w/ 10.6 comp and s100? Thanks again.
Location: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Re: In what intervals are tial springs available? 10psi? (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral »</TD></TR><TR><TD CLASS="quote">Why don't you just get a lower spring rate and use a boost controller?</TD></TR></TABLE>
I have a .3 bar spring with a Profec B boost controller, seems to work just fine.
