Missing Link? Greddy blue box
Old Apr 11, 2003 | 11:57 PM
BlackB18C's Avatar
Default Missing Link? Greddy blue box
I'll be installing a greddy turbo kit including the "blue box" on my 99 gsr motor and I was wondering if I will need the "missing link" or if the blue box will handle any unwanted cel's. Thanks in advance.
Old Apr 12, 2003 | 02:23 AM
5thgencivic's Avatar
Default Re: Missing Link? Greddy blue box (BlackB18C)
Yep. Does on my sohc kit anyway.
Old Apr 12, 2003 | 09:56 PM
b18c195's Avatar
no u dont need a missing like if u are using the blue box.
Ur only gonna need one if ur using something like a vortec fmu or something like i am
Old Apr 12, 2003 | 10:19 PM
biassj's Avatar
Default Re: (b18c195)
Yea no missing link. Are you running the 310cc injectors too? It's gonna be hella rich.
Old Apr 15, 2003 | 12:46 AM
BlackB18C's Avatar
Default Re: (biassj)
Just got my car running today and had a chance to drive it a bit. I am running 310's and yeah I know it's gonna be rich, I'm hoping to pick up the new hondata within the next month and tune out a little more power. I'm getting a check engine light if I get up towards redline 7800 rpms...somewhere in there. Then if I shut the car off and start up again it goes away. I was told that I may need a check valve? Can anyone shed some light on this issue?
Old Apr 15, 2003 | 05:19 AM
The Crow's Avatar
Default Re: (BlackB18C)
Stay away from the blue box of death. You'll do better with a msd btm, a missing link, and a vfac.
Old Apr 15, 2003 | 06:03 AM
Pengo's Avatar
Default Re: (The End)
you don't need a check valve if ur running blue box. you may need to turn ur fuel pressure down a tad bid if ur running those injectors tho. with stock fuel press and 310s and a walbro 255 i had a terrible idle. blue box of death? damn then i must be immortal. i think its a good low boost solution over an fmu if installed properly. blue box, 310s, walbro, aem fpr, 1 colder plugs at 6-7 psi on my sohc and i've never had any CELs or detonation. of course rite now i'm prob running rich as hell until i get on the dyno
Old Apr 15, 2003 | 06:19 AM
BLKMamba's Avatar
BMW Güdentyte
25 Year Member
Default Re: (Pengo)
No missing link needed if your running the blue box. The blue box alters the readout of the MAP sensor.
Old Apr 15, 2003 | 11:44 PM
BlackB18C's Avatar
Default Re: (DB8GSR)
Thanks for the info. Colder plugs are on the way and I'll probably pick up a fuel pressure regulator.
Si_Element
Aug 18, 2006 12:35 PM
wiz321654
Nov 5, 2005 03:17 PM
HP_em1
Sep 29, 2005 07:21 AM
lDanny
Mar 30, 2005 02:14 PM
311
Jun 15, 2004 02:48 PM
