Drawbacks to running near zero boost?
Old Apr 10, 2003 | 09:46 PM
spl_nut's Avatar
Default Drawbacks to running near zero boost?
I've got a 97HX with higher miles... Recent articles and threads I've read have me convinced I can boost (t25) for under 1K. 80% of the time I'll drive it like Mr. Roger's grandmother...
Drawbacks to running an adjustable boost controller, and dialing it down to near zero for daily driving? Is this possible? Or, is keeping shift point below the boost range more pratical?
I'd like the engine to last, until I decide on it's replacement... Was thinking 6lbs max (should develop around 150-60hp?)?
Thanks guys...
Old Apr 10, 2003 | 09:56 PM
AB16A2T's Avatar
Default Re: Drawbacks to running near zero boost? (spl_nut)
I believe you can't go below the spring set PSI. Someone correct me if I am wrong, sides you'll only get full boost if you romp on the gas and run it through the RPMs, just drive normally, shift before 4k RPM, and you should be fine.
Old Apr 10, 2003 | 10:07 PM
spl_nut's Avatar
Default Re: Drawbacks to running near zero boost? (AresB16A2Turbo)
Thanks for the info!
It's been a learning process... and I've got a long way to go!
Old Apr 10, 2003 | 10:13 PM
Pengo's Avatar
doesnt matter if boost controller is set to 6 psi or 20 psi. you can daily drive without hitting boost. you just have to learn to be light with the gas and control ur foot. i've gone days without ever even going into boost.
Old Apr 10, 2003 | 10:23 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: Drawbacks to running near zero boost? (Pengo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pengo &raquo;</TD></TR><TR><TD CLASS="quote"> i've gone days without ever even going into boost.</TD></TR></TABLE>
I wish I could say the same but my foot is very heavy
Old Apr 10, 2003 | 10:32 PM
spl_nut's Avatar
I suspected this, needed to hear it from people who know - thanks man.
I just want the engine to last a while - and if I shift under 3K, I get 40+mpg in town - nice little bonus :D
Guess I'm off to find a mitsu T25
bigtom388
Nov 21, 2009 12:30 PM
pjr710
Jan 5, 2009 11:15 PM
rdeezy78
Aug 27, 2007 03:19 PM
nigel
Mar 24, 2004 05:29 PM
uneekcrx
Jul 11, 2002 02:44 PM
