inlinepro manifold users??
Old Apr 13, 2003 | 02:38 AM
GOLDBERG's Avatar
Default inlinepro manifold users??
did you have to shave your block for turbo to fit??also was there any clearance issues with the wastegate and the hood when mounted on the flange???also post what turbo you used, car, etc..thanks alot
p.s .inline pro manifold dyno #'s would be awesome
Old Apr 13, 2003 | 05:22 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: inlinepro manifold users?? (GOLDBERG)
If you use an E housing will not need to cut any thing off. This is why I love this manifold. It saves at least an hour trying to cut the block. But remember this is only with the 5-bolt turbine housing.
You can fit the wastegate if you dont use the top port. Or you can run a Turbosmart wastegate that is shorter than the tial wg.
Dyno at 7.25psi and 3 cylinders...
Old Apr 13, 2003 | 11:03 AM
GOLDBERG's Avatar
Default Re: inlinepro manifold users?? (Arturbo)
what about with a t4/60-1?? or a t3/60-1..would i need to cut any of the block?? i'm probably going to run a t3/t4 with .82 ar.. but am not definate yet....also why does 5 bolt housing and 4 bolt housing differ so much???
Old Apr 13, 2003 | 11:59 AM
g2turbo's Avatar
look into a precision turbo. I am pretty sure that you will have to shave the block with a 60-1 t3. Arturbo did a nice tech article on this if you search. But you might want to look into a precision turbo. No shaving and better turbo IMO than the 4 bolt garretts
Old May 3, 2003 | 05:27 AM
GOLDBERG's Avatar
art what motor was that on???
and bump.there gotta be more inlinepro users around
Old May 3, 2003 | 05:39 AM
Arturbo's Avatar
Better than steak
25 Year Member
made on a stock gsr motor with one cylinder reading 90psi.
Old May 3, 2003 | 06:42 AM
FredoSP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">made on a stock gsr motor with one cylinder reading 90psi. </TD></TR></TABLE>
and the color of the car was white
Adi_King
Jan 14, 2015 10:09 AM
Kevin
Jun 16, 2009 12:40 PM
alpha_1
Nov 18, 2005 07:49 AM
dnbruut
Mar 18, 2005 03:06 AM
2.2
Sep 17, 2002 07:13 AM
